Stripped c6
Old Jan 31, 2024 | 12:37 PM
c6Dylan's Avatar
c6Dylan
7th Gear
Default Stripped c6
So I recently got a c6 from a salvage yard that was completely gutted, they took everything from the engine to the rear cv axles. I was wondering if it is possible to run a standard engine/transmission setup on a solid rear axle to save some money or would it be better to just rebuild the transaxle and diff like oem
Old Jan 31, 2024 | 12:50 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Welcome, moving you here to C6 section for possible answers good luck
Old Jan 31, 2024 | 01:46 PM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
I guess the question I'd ask you first is are you building a racecar or a street car? If the first one, yeah its been done, but its pretty involved and takes some cutting and fabrication. Cleetus Mcfarland's Leroy Vette Cart went to this setup, several others have done it too. If your building a street car though... stick with the factory style setup.
Old Jan 31, 2024 | 02:27 PM
c6Dylan's Avatar
c6Dylan
7th Gear
Default Stripped c6
Originally Posted by StayinStock
I guess the question I'd ask you first is are you building a racecar or a street car? If the first one, yeah it’s been done, but it’s pretty involved and takes some cutting and fabrication. Cleetus Mcfarland's Leroy Vette Cart went to this setup, several others have done it too. If you’re building a street car though... stick with the factory style setup.
It’s gonna be a street car, if I go factory trans and diff what engines will the torque tube fit besides ls3/ls7 (the car is an 09)
Old Jan 31, 2024 | 08:24 PM
davidfarmer's Avatar
davidfarmer
Any LS will bolt up.
Old Jan 31, 2024 | 08:27 PM
kkupec02's Avatar
kkupec02
welcome
Old Feb 1, 2024 | 08:02 AM
StayinStock
Yeah def stick with a torque tube transaxle setup if your going to build a street car. Live axle conversions are racecar stuff lol. Any LS/LQ variant will fit. Did they leave the computers and electronics? If so I would try to stick with a 58x variant just for simplicity sake (so gen 4 motors)
Old Feb 15, 2024 | 03:12 PM
yeller z06's Avatar
yeller z06
Wow. You are a brave man. Best of luck!
Old Feb 16, 2024 | 07:42 AM
jayyyw's Avatar
jayyyw
A good solid rear end swap won't be any cheaper than piecing together the factory drivetrain. There's no kit out there that just bolts on.
If the car is an '09, you need an '09+ torque tube out of any manual vette. CV axles also need to be '09+ since they changed the hubs in that year.
Old Feb 20, 2024 | 04:47 PM
c6Dylan's Avatar
c6Dylan
7th Gear
Default Auto or manual
For simplicity sake Ill rebuild the factory drivetrain. However, I'm still on the fence about whether to put a 6l80 in it or do a manual conversion. Beyond the torque tube, trans/diff, and the cv axles what would i need to make a tr6060 swap happen in my automatic 09 base model vette?
To Stripped c6
