Currently being installed H/C, LT headers w/Corsa Extremes, E-Force supercharged and RPM Stage 3 rear differential 3.73. Anyone have a similar setup, if so how do you like it? Would you do anything differently?
Theyll help with traction. But as others have said, it'll put an increased load on the trans and diff. The diff will probably be OK, but the trans may not be for too long.
are you driving around town or just tracking it? Only reason I am asking is I had a C4 with 4 speed tran, 3.73's and didn't like it. I have lots of interstate near me, which is where I had the issue.
I have a converter if you need one? It was a little too much for my setup but I'm spinning a ported Eforce about as fast as you can spin one.
