Slave Cylinder Clip
Old Feb 13, 2024 | 08:06 PM
JL3100AD's Avatar
JL3100AD
Default Slave Cylinder Clip
I lost this clip while installing my tick master cylinder, anyone know where you can get one? I've looked everywhere and about to give up.
Old Feb 13, 2024 | 08:50 PM
torquetube's Avatar
torquetube
You could get a clip from an old slave cylinder. If you share your location and/or ask in a regional forum you might find somebody who has one.
Old Feb 14, 2024 | 08:12 AM
robert.m.kalis's Avatar
robert.m.kalis
I had lost mine when replacing the clutch master cylinder. Pulled the bolts at the bottom of the fender out and flexed the fender out and the clip fell out to my surprise! I removed the washer fluid tank to give me better access, and loosening the bottom of the fender helped in that regard.
Old Feb 14, 2024 | 10:30 PM
JL3100AD's Avatar
JL3100AD
lucky you, i'm almost certain mine went in the frame
Old Feb 15, 2024 | 11:05 AM
Nowanker's Avatar
Nowanker
Pro Mechanic
I try to save leftover 'stuff' like that when I do any work... just for those occasions.
I might have one in my box of misc clips.
If someone can post a picture/drawing with dimensions, I'll look through it.
Meanwhile, keep looking.
And, just by chance... anyone here have a shift rod detent spring for a 944 gearbox?
To Slave Cylinder Clip
