P0300
Old Mar 2, 2024 | 09:35 AM
wood78221's Avatar
wood78221
Default P0300
Anyone had this code displayed on the OBD2 scanner without any symptoms? I know it's a box of worms or so it seems.
Old Mar 2, 2024 | 10:22 AM
Vette_DD's Avatar
Vette_DD
P0300 Engine Misfire Detected ECM
Old Mar 2, 2024 | 10:28 AM
kestell123's Avatar
kestell123
If this is the first occurance I would clear the code and see if it returns. If it returs you will need to look further into it.
Old Mar 2, 2024 | 10:54 PM
DrKrieger's Avatar
DrKrieger
Check your plug wires for good contact at both ends of the plug wires. You may want to pull the plugs to see how they are burning, and make sure the gap is proper. Also, once you do this approach, then disconnect the battery for 30 seconds or so, then re-connect, start the car, and see if the code clears by resetting the ECU .
To P0300
