2005 Corvette Electronics Acting Up
Old Mar 5, 2024 | 03:50 AM
Sweebation's Avatar
Sweebation
Default 2005 Corvette Electronics Acting Up
Hello, I recently rebuilt my engine and I just finished putting everything back in, when I went to put it into accessory mode it just clicked, the radio and light turn on, the seats work, and the horn works but the windows, locks, and door buttons do not work and the car will not go into accessory mode. I think it’s probably low voltage as this was with ~9 volts so I’m letting it charge overnight but I am curious if there are any other issues that may be causing this? Thank you!
Old Mar 5, 2024 | 09:14 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If not only recharge the battery but you should have it load tested…if the battery is good I would go from there.
Old Mar 6, 2024 | 12:29 AM
STLC6's Avatar
STLC6
Adjust the battery connections. My 05 does this too, so did my 02 camaro. If i loosen , adjust and retighten battery cables, problem goes away. Can't hurt to try
To 2005 Corvette Electronics Acting Up
