c6 fans
Old Mar 6, 2024 | 02:48 PM
Alexandra Z's Avatar
Alexandra Z
Default c6 fans
we have a 05 corvette i replaced the battery. Now the heater a/c fan does not work or the fan for the radiator fan does not work either. We checked all the fuses and the relays and they are all we also checked the fan plug at the radiator to see if it is bad, but it is also good. Now the check engine light is on i need help.
Old Mar 6, 2024 | 03:09 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Find a scan tool and see what DTC or DTC’s you have…may help in a diagnosis.
