Help, Rev after engaging clutch
Old Apr 9, 2024 | 11:11 AM
Kyle91's Avatar
Kyle91
2nd Gear
Default Help, Rev after engaging clutch
Hi, I sure hope someone has an answer!
My 07 recently started revving up between 500-800 RPM when I disengage the clutch, shortly after that I had a pin size hole in the radiator so took it to my mechanic to replace the radiator and they also tried to figure out the problem with the rev. They replaced a secondary clutch sensor which showed up in the codes, but no other codes. They cleaned the throttle body and everything they could thing of, they couldn’t really figure it out. After I got it back it would hold the rpm where it was at when I disengaged the clutch for a couple of seconds then would drop, idk if they are built that way, but mine always drove like and old school car and when you pushed the clutch in the rpm would drop to idle. This was fine but now after about a week it’s started revving rpm again when I press the clutch in. I’ve read about the idle relearn and attempted that but idk that it worked and again no codes are showing up.
Old Apr 11, 2024 | 01:18 PM
torquetube's Avatar
torquetube
Lazy return to idle without codes is often caused by a vacuum leak.
Old Apr 11, 2024 | 02:36 PM
Kyle91's Avatar
Kyle91
2nd Gear
@torquetube all that was check as well. Did a relearn it seems to be slowly relearning will keep at it.
To Help, Rev after engaging clutch
