Header instal estimate
![](/forums/images/ranks/5k-6k.gif)
St. Jude Donor '06-13,'16-'17, '19
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
![BS](https://www.corvetteforum.com/forums/images/smilies/icon_bs.gif)
Tom
![](/forums/images/ranks/1k-2k.gif)
Tom. Yes there are other considerations if your diy, but a shop has a lift and even at that the op shop was charging like 500 an hour shop time that's a rip off and there
Is no justification
Is no justification
![](/forums/images/ranks/4k-5k.gif)
Received 3,494 Likes
2023 C6 of the Year Winner - Modified
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
![](/forums/images/ranks/7k-10k.gif)
Ill give ya maybe 3 hours tops if you have to contend with the dry sump oil lines but... on a wetsump car if you cant have the entire exhaust on and off the car in less than 2 hours your just not trying. I'll give ya 30 mins if you have a stuck o2 sensor. Work on flat rate for a few years, you learn to get fast. You can drop the craddle and have the balancer off one of these things in 4 hours if your cranking... I'd work on a C6 over any GM car any day... you want to talk about a bad job try pulling/replacing the motor out of a TBSS... that one took years off my life.
