How to replace Right Rear ride adjuster bolt, 2011 GS
Can someone please share a video or describe the step by step procedure for replacing only 1 rear side height adjuster?
I will be using jack stands and a floor jack.
Thanks for your help
I could just start unbolting stuff but I'm sure there are some lessons learned from you experienced members I would like to take advantage of
Cheers
Cheers
Maybe this will help. Document attached. The last page has an alternate method that releases the spring pressure on the bolt to ease adjustment/removal. That method intrigues me, although I have not attempted the procedure.
Good luck and let us know how you proceed?
GD
GD
GD
GD
On my 07 z51 I had to unbolt the upper A arm to get enough clearance to remove the levelers, then the lower A arm will drop down far enough, just rotate the knuckle and axel shaft out of the way. Mine did have the z51 package so they were pretty stiff.
I did a jack under the lower A arm and took it barely off the jack stand for tightening, could also just put blocks under the lowers and put it all the way down.
Does it need an alignment after doing that? I had to.
robert.m.kalis (04-29-2024)
