Fuel smell at fill up help please
Hello,
2011 base coupe
fuel smell after fueling and a short time rough running too led me searching.
no check engine or any codes
I replaced purge valve at right front valve cover just cause easy
I looked at right rear evap area for anything odd and I see a vac or fuel line rubber with a tee that is open on the top.
see pics and please advise if normal or did it come off or break.
top of tee not attached to anything
2011 base coupe
Spoiler
The most common cause of a raw fuel smell on C6s is the top of the fuel pump assembly cracks and leaks fumes. You'll have to drop the fuel tank to replace but but with a good bore scope you can probably get up there to look.
anyone know about the tee in my pics?
should it be open at the top?
last fill up car ran real rough and died
started back and bad idle for a few more miles
please see pics of the tee back right above axle pipe
thank you!
