Help!
Old Jul 27, 2024 | 04:41 PM
mnorth04's Avatar
mnorth04
Default Help!
I just finished a fast lsxr intake install. I go to start the car and have 0 oil pressure and the car won’t turn over. Turns out I forgot to plug the oil sending unit connection back in, so I take off the fuel rails and plug it back in and briefly get the car to start and read pressure. As soon as it starts it shuts back off and the pressure goes back down to 1 psi. I’ve been reading that a bad sending unit/sensor is a common issue for the c6, but would that prevent the car from starting?
Old Jul 27, 2024 | 05:10 PM
jamieo's Avatar
jamieo
I had an oil pressure sensor fail on me and it showed 0 oil pressure but still started and run fine.Drove it home like that to replace it.Don't know if that helps or not.
Old Jul 27, 2024 | 07:10 PM
Rydman313's Avatar
Rydman313
Cruising
I drove mine with a dead oil pressure sender for a month before I got around to replacing it. Car ran fine, but not seeing pressure drove me nuts....
Old Jul 28, 2024 | 03:04 PM
helga203's Avatar
helga203
No it wont
Over heating will
Old Jul 28, 2024 | 05:06 PM
mnorth04's Avatar
mnorth04
Originally Posted by helga203
No it wont
Over heating will
I hadn’t started the car for a few days prior so how would overheating be the issue?
Old Jul 30, 2024 | 03:51 AM
torquetube's Avatar
torquetube
The engine only makes oil pressure when it's running.
No. Something else is wrong.
Old Jul 30, 2024 | 08:57 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
I hate to be that guy and state the obvious but check your battery, its possible you killed it while it was down being worked on. I've done it many times. Low voltage makes these cars do screwy ****. Could be possible you have a bad sending unit but my guess is you've either unpluged something or messed up a connection somewhere since you had it apart. Just retrace your steps and check your voltage at the battery.
Old Aug 1, 2024 | 06:31 AM
Jfryjfry's Avatar
Jfryjfry
Check your fuel line connection It could not connected properly.
To Help!
