Radio Replacement with factory AMP delete
Old Aug 21, 2024 | 04:19 PM
SilverSurfer_LS3's Avatar
SilverSurfer_LS3
Default Radio Replacement with factory AMP delete
I just purchased a 2011 C6 with the factory Bose sound system and there is no sound through the speakers. Been reading through the forum and it looks like it probably is a bad amp.
I am looking at replacing the factory radio with an aftermarket head unit with android auto. I would like to just use the head unit for the output a delete the factory amp.
Could someone help point me in the right direction for a plug and play harness. I searched the forum but didn't find anything that was very helpful.
Old Aug 21, 2024 | 04:34 PM
ValenciaOrange's Avatar
ValenciaOrange
Hope you find an easy solution. When you were inspecting the car, did you try the radio?
Old Aug 21, 2024 | 04:38 PM
SilverSurfer_LS3
I was planning on replacing the radio when I bought the car so it wasn't a big deal, or so I thought. I originally thought it was just a bad head unit.
The head unit turns on fine and everything seems to work fine, just no sounds out of the speakers or any chimes and what not either.
To Radio Replacement with factory AMP delete
