Starting Problem
Old Aug 21, 2024 | 05:05 PM
quemqn71's Avatar
quemqn71
Default Starting Problem
2005 Coupe, started at first in order to change wiper blades. When finished try to start and now only get a clicking sound. No start. Would the started go bad that fast?
Battery has full charge. Window indexed down but not up. Check engine indicated comes on for a few seconds. No FOB notice comes on for a few seconds. Since car is in garage I probably will need it towed to dealership. What is approximate cost I can expect from "Stealership"?
Old Aug 21, 2024 | 05:18 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
We can’t estimate how much this will cost because we can’t give you a firm diagnosis…it can be anything from a battery to a starter or worse…I think dealerships diagnostic fee is $150.00 an hour and labor maybe $225 or more…dealerships usually just replace parts so don’t expect to pay for just one part…find a shop that will diagnose your car and not just throw parts at it.
Old Aug 21, 2024 | 05:22 PM
quemqn71's Avatar
quemqn71
Thanks for the reply. I just put $4500 into repairs for A/C, Harmonic Balancer, Filters and Recharge A/C. Mechanic pointed out there is another $4000 of work that will be needed soon on items such as Rack & Pinion, Tires, Brakes. This is not the dealership either. Is it time to sell and move up to C7 or C8?
Old Aug 21, 2024 | 05:29 PM
C5 Diag's Avatar
C5 Diag
I see from of your other posts that you may be in my area…if you want I can take a quick look at your car.
To Starting Problem
