Swapped 05 Code Trouble
Old Sep 4, 2024 | 09:06 PM
TimW314's Avatar
TimW314
2nd Gear
Default Swapped 05 Code Trouble
Hey guys,
im working with an 05 M6 car but has been swapped with a 6.2L truck motor and a TR6060 & diff from a 2012 car
car still uses the 05 harness with a reluctor wheel converter box
currently having some codes and looking for some insight
B0976, C0575, C0590
im not sure exactly what they refer to im trying to research a little now, if anybody has some info on what the codes refer to i would very much appreciate the help.
thank you
Old Sep 5, 2024 | 09:39 AM
H8 mondays's Avatar
H8 mondays
I found a list of error codes of the 05 and the B0976 POWER MODE OFF INDICATOR CIRCUIT BCM, C0575 is LEFT FRONT SOLENOID/MOTOR ACTUATOR CIRCUIT ELECTRONIC SUSPENSION CONTROL, C590 IS THE RIGHT REAR SOLENOID/MOTOR ACTUATOR CIRCUIT ELECTRONIC SUSPENSION. Hope this helps good luck.
Old Sep 5, 2024 | 10:01 AM
Vettelagged's Avatar
Vettelagged
The last 2 sound like the BCM is searching for the air ride sensors, I had this on my Avalanche when the rear suspension was replaced with aftermarket shocks. There is a by pass you can buy, I think it was like $40 when I needed it.
To Swapped 05 Code Trouble
