Battery Check
Old Sep 20, 2024 | 11:04 AM
DESI6327's Avatar
DESI6327
Default Battery Check
Can I rely on my dash to give me an accurate Voltage reading? I’m showing 14.2 driving and at times, 13.8 at idle. Still have warnings popping up but no problem. Time for a new battery? Can’t find a date on it.
TIA
Old Sep 20, 2024 | 11:10 AM
cadbob's Avatar
cadbob
Warnings Popping up? Your Voltages seem fine, look for a place that will load test battery for you if it is of concern
Old Sep 20, 2024 | 11:59 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
TIA
No, dash voltage is usually 0.4 volts or so lower than AT the battery…what warnings ??…if you have no electrical skills take the car to an auto electric shop…if the battery is discharged the battery voltage will be higher and as it get charged it will decrease…if you suspect a battery have it checked.
Old Sep 20, 2024 | 01:28 PM
DESI6327's Avatar
DESI6327
I have a tester, just bought it. Will check at battery. Warnings are minor. Come and go. Tire pressure sensor, passenger airbag, then go away.
Old Sep 20, 2024 | 01:31 PM
DESI6327's Avatar
DESI6327
[QUOTE=cadbob;1608186846]Warnings Popping up? Your Voltages seem fine, look for a place that will load test battery for you if it is of concern[/QUOTE
Forgive my ignorance. “Load test?”
Old Sep 20, 2024 | 02:06 PM
C5 Diag's Avatar
C5 Diag
[QUOTE=DESI6327;1608187266]
Load testing is where they put a big resistor across the battery terminals and check your battery…that test is more old school…I do a capacitive battery test these days which is a much better test….just bring your battery to Auto Zone and let them test it.
Old Sep 20, 2024 | 04:41 PM
DESI6327's Avatar
DESI6327
[QUOTE=C5 Diag;1608187366]
thank you!!!
Old Sep 20, 2024 | 10:21 PM
DESI6327's Avatar
DESI6327
Thank you! Warnings:Tire Pressure Sensor, Passenger Airbag. Then they disappear
To Battery Check
