2013 Convertible
Old Oct 12, 2024 | 11:09 PM
mlsins's Avatar
mlsins
Default 2013 Convertible
Hey all, I blew a fuse using a tire pump in the cigarette lighter. Got that fixed and have checked all the other fuses as well as the usual trouble points with the top but there is no power to the pump. Any ideas on where the problem might be?
Old Oct 13, 2024 | 06:50 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What do you mean by “usual trouble points “WITH THE TOP”….do you have a 12 volt test light to check the circuit ??
