DBA 4000 Rotors issue ?
Old Oct 27, 2024 | 12:35 PM
C6Z06Silverbullet's Avatar
C6Z06Silverbullet
Default DBA 4000 Rotors issue ?
So about a year ago i swapped out my stock rotors for a set of DBA 4000 rotors. So now when braking they are noisy, its hard to explain. Not a squeaky noise but like i can hear the pads hitting the rotors and feel it. Pads are fine and brand new. I even changed them out to see if it was a pad problem and its the same. Anyone else have this problem? Or am i in the corvette abius by myself ?
Old Oct 27, 2024 | 06:42 PM
B y r o n's Avatar
B y r o n
Did you notice any rub/scrape marks on the hub/rotor?
Old Oct 27, 2024 | 06:50 PM
C6Z06Silverbullet
no rotors look perfect
Old Oct 27, 2024 | 08:14 PM
Dano523's Avatar
Dano523
Pad metal backing plate, to calipers metal surface itself.
Hence did you use Brake silicone grease on the back and sides of the pads metal back plate, before they where installed.
And if you are power washing the car a lot, may have to pull the pads to clean, and re-grease them every so often as well.
Simply, short of using a very aggressive racing pad that its pad surface to rotor surface itself can make the squealing noise, most of the time when you have break squeal, its the pad metal backer plate that is making the noise, from dry metal on dry metal, as the pad is vibrating in the caliper during braking.
Also, when you install the caliper to begin with, make sure to pull the sliding pins to make sure they are pulled, cleaned and greased as well.
Old Oct 27, 2024 | 09:04 PM
C6Z06Silverbullet
Thanks for the reply but it's not a squeal. Yes everything has brake lube. The pads are powerstop Z26 so they are not aggressive.
Old Oct 29, 2024 | 04:46 PM
Dano523's Avatar
Dano523
Photo of rotor surfaces, since pads may have melted to rotor surfaces, and that is causing the noise.
Also, photo of pads,since if leading and trailing edge not edge tapered/ chamfered, could be causing the noise as well.
Or could be that rotors and pads are glazed from not hard enough stops to break the glazing,and may have to de-glaze both by hand isntead.
As for Powerstop pads, I do not run them since they do offer a heat range charts for any of their pads, so don't have a clue on what pad is best for what.
Old Oct 29, 2024 | 05:07 PM
C6Z06Silverbullet
Nothing is melted to the rotors, pads are tapered/ chamfered. Pads are not glazed just replaced them thinking the pad could be the problem. Used the same brand pads on my stock GM rotors with no problems. Which is another reason it makes me think its possibly the rotors. Also only happens in the rear, and its not a constant. Its not a metal to metal noise or a squealing noise. It feels like its metal to metal when it happens. Very weird.....
Old Oct 30, 2024 | 10:20 AM
Kenny94945's Avatar
Kenny94945
If I understand this noise began 1 year after your rotor and pad swap.
You change the pads yet the noise remains, assuming you greased everything again.
I am with Dano on this, regrease.
Since this is a new noise that began after a year of wear, there are limited things to check.
Check rotor runout, deglaze the rotors, chamber/ smooth the pads, caliper pad pin replacement, inspect caliper pistons, look for wear marks/ damage on the calipers, double check the torque on all related bolts, and ensure the rotor is flat to the hub.
A brake fluid bleed or flush to ensure no line is clogged could also be recommended, and don't forget to use a Tech II, or like, to open the ABS valves.
Lastly, noises are sometimes hard to locate.
You may think it is brake related, may be suspension related and what you think originates in the front may actually originate from the rear.
All FWIW Good luck
Old Oct 30, 2024 | 12:48 PM
Sayfoo's Avatar
Sayfoo
Are you an aggressive driver?
Have you recently gotten the brakes real hot?
SOMETIMES, a few really hard, hot stops will cure a noise, especially if a car is driven easy.
Old Oct 30, 2024 | 04:09 PM
C6Z06Silverbullet
All FWIW Good luck
Everything has been greased fresh when i did the pads a couple days ago. Inspected all and cleaned everything. Just did a complete flush a year ago with AMSOIL. I did bleed both sides to check for air and there was none. Calipers looked fine to the eye. No I didn't deglaze the rotors. I will hit them with some scotch bright pads when i get a chance. Noise if definitely in the back. One thing you mentioned was opening up the abs valves, When i did the flush with my vacuum pump I did not do this. Think this could be the cause? Was not aware that i needed too.
Old Oct 30, 2024 | 04:12 PM
C6Z06Silverbullet
No I'm not an aggressive driver, i would say spirited at times. I didn't buy the car to ***** foot it around but I'm not hard on the brakes either. Car is not a daily at all and does not see any bad weather. 2006 with only 22,000 miles.
To DBA 4000 Rotors issue ?
