2006 Z06 Engine Noise
Old Nov 9, 2024 | 11:16 AM
vetdude's Avatar
vetdude
Default 2006 Z06 Engine Noise
Bought new in '06. Engine has developed a "rattle" on start up. Oil level good after checking when warm. Oil pressure 51 at idle. Harmonic balancer good. Mileage: 6,302. Any ideas?
Old Nov 19, 2024 | 09:45 PM
bwill03z's Avatar
bwill03z
Most likely you have one or more lifters bleeding down and the rattle you hear is them pumping up…if you’re pretty certain the noise is coming from the motor. If it goes away as the motor warms up I would not worry about it
