One high beam doesn't work
Old Nov 19, 2024 | 03:32 AM
Tom2005issue's Avatar
Tom2005issue
Default One high beam doesn't work
I checked relays and fuses for high beams all good one high beam works perfectly looks amazing but another is ever so slightly on when I start my car and low beams are on but when I switch the column to high beams it shuts out. I thought it was the relay but the diagram shows if the relay was bad then would both shut down the diagram shows its a straight forward path relay fuse and then bulb so what could be the issue bad ground, maybe corrosion?
Old Nov 19, 2024 | 10:57 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Start by pulling the connector at the lamp to make sure it's clean & corrosion free. Use some dielectric grease when you reconnect.
Old Nov 19, 2024 | 02:08 PM
Tom2005issue
no luck I switched all lights out low highs turn and fog didn't see corrosion on the connection them selfs
Old Nov 19, 2024 | 02:26 PM
Vettelagged's Avatar
Vettelagged
Is it possible the ballast is bad?
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Ground issues are more prevalent than power issues so check G101 or 102…you didn’t say which side is out…C119 and 120 is the headlight connector where you should check…do you know how to check for a proper ground ??
Old Nov 19, 2024 | 03:08 PM
Tom2005issue
the ballast is only for the low beams the highs are a polarity bulb like every standard bulb so the wiring is straight forward
Old Nov 19, 2024 | 03:09 PM
Tom2005issue
thank you so much but i was looking at that exact diagram sheet and thought it weird because the fuse nor the relay is out so power wasn't the problem
Old Nov 19, 2024 | 03:32 PM
C5 Diag's Avatar
C5 Diag
To properly check a ground you have to dynamically “load” the circuit…each high beam draws about 5 amps so you want to get yourself an old headlight like I’m using below that draws 5 amps…connect one lead to B+ and probe the ground terminal on the headlight connector…the black wire is to ground so if you probe the ground with the other lead the test light should be bright…if the ground can’t carry that 5 amps back to the battery your high beam will be dim or not work at all…looking at the OE wiring there is another connector other than C119 and C120…C121 and C122….sorry !!
Old Nov 19, 2024 | 04:50 PM
oldcanuck's Avatar
oldcanuck
Did you test the bulb(s). You could even do it by reversing which is in each hole to see if you get the same result.
Old Nov 20, 2024 | 01:22 AM
Tom2005issue
still no dice but the old bulb looked fine nothing out the new one is a led and kn the other side it looks good
To One high beam doesn't work
