Header install
Old Nov 29, 2024 | 12:03 AM
David@Nina's Avatar
David@Nina
7th Gear
Default Header install
I am putting Billy Boat PRT axel back exhaust on my 07 base convertible and I want to put headers on it also. The new headers have ports for the o2 sensors. Do I need to replace the oem h pipe with a x pipe?
Old Nov 29, 2024 | 01:57 AM
jamieo's Avatar
jamieo
Yes.Make sure you get the same brand x-pipe as the headers so everything will fit correctly.
Old Nov 29, 2024 | 06:55 AM
David@Nina's Avatar
David@Nina
7th Gear
Originally Posted by jamieo
Yes.Make sure you get the same brand x-pipe es the headers so everything will fit correctly.
Thanks for replying to my question.
Old Nov 29, 2024 | 12:58 PM
HK770's Avatar
HK770
Leave headers a bit loose till you attach X pipe. If not You Will bet!
Old Nov 29, 2024 | 11:20 PM
David@Nina's Avatar
David@Nina
7th Gear
Great advice, thanks.
Old Nov 29, 2024 | 11:52 PM
tennblkc6's Avatar
tennblkc6
wrap starter while you have headers off
Old Nov 30, 2024 | 07:01 AM
Malfeitor's Avatar
Malfeitor
Definitely this.
Old Nov 30, 2024 | 08:38 AM
Dreamer2's Avatar
Dreamer2
Do the wires or anything else need shielding? I would probably do a tunnel heat shield also.
Old Nov 30, 2024 | 05:28 PM
Malfeitor's Avatar
Malfeitor
Not running any plug boot socks etc. I drilled a hole in my tunnel plate right where the O2 wires come out of the cat/mid pipe and ran them above the tunnel plate. Not having any issues at all. A little heat soak on the starter in the summer if I get spirited but it starts every time. (A little slower starter speed....)
Old Dec 2, 2024 | 10:29 AM
3X2's Avatar
3X2
additional things I do when installing headers:
1- wrap the starter housing and solenoid.
2- use metallic heat shield (i.e. DEI) on the primary tubes closest to the starter and oil cooler pipes, secure with metal self locking band straps. It comes in sheets, cut as needed with tin snips.
3- I cut the tunnel plate into 2 pieces right where there is a notch in the tunnel, between the 4th and 5th bolt, and notch one side of the plate then run the O2 wires up in between the tunnel plate and torque tube.
4- fire sleeve the O2 connectors and secure as far away from the headers as possible with wire ties.
5- fire sleeve the 2 trans cooler pipes where they go over the right side header collector.
6- wrap the right side header collector at the trans cooler pipe area, see #2.
7- fire sleeve the 2 heater hoses.
8- add additional fire sleeve to the wire harness behind #8 primary tube.
9- add a small piece of fire sleeve over the purple wire and connector on the starter solenoid.
10- rotate the knock sensors as needed for additional clearance and secure wiring with wire ties.
11- fire sleeve the clutch slave cylinder line.
12- depending on header brand, heat shield #7 primary tube if close to slave cylinder line.
13- add heat boots to the plug wires and secure the coil end with wire ties.
14- if not already there, fire sleeve the engine mounts.
15- use high temp antisieze on all the bolts and the oxygen sensors.
16- no header wrap. I also have had high temp coatings peel off. May work ok for a street car.
17- check for clearance between the chassis flange and where the 4 tubes join the collectors on both sides. Depending on header brand, I have had to bend the chassis flanges with a hammer. Not required on aluminum frame cars.
Old Dec 3, 2024 | 07:54 AM
Dreamer2's Avatar
Dreamer2
Do ceramic coated headers negate any of the above?
Old Dec 3, 2024 | 08:17 AM
3X2's Avatar
3X2
I do not know. I do these weather or not the headers are coated.
Old Dec 5, 2024 | 03:13 AM
David@Nina's Avatar
David@Nina
7th Gear
Default Thanks for sharing your well detailed knowledge. I am a first time corvette owner. I.
  1. ​​​​​​​​​​​​​​
To Header install
