P0335 and P0340 codes not starting
Old Dec 26, 2024 | 01:38 PM
  #41
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
No precautions…just make sure you jump the right ones…the RUN/CRANK RELAY on the back of the BCM when it receives the correct inputs from the FOB and brake petal switch energizes terminal 86 of CRANK RELAY 43….you can check if it energizes by probing terminal 86 during starting for 12 volts or at ECM Fuse 12…if voltage or test light illuminates run/crank is good…the solenoid is clicking so looks like power is getting down to the solenoid…the starting system for my 08 is a little different as far as the “control” side of the starting system.
Old Dec 26, 2024 | 02:01 PM
  #42
turnerg1's Avatar
turnerg1
ok the first time it cranked. Surprised me so I pulled it out. 2nd time I got the hollow clang and it shocked the snot out of me. Didnt crank but it was such a fast shock i threw the paper clip.
Old Dec 26, 2024 | 02:09 PM
  #43
C5 Diag's Avatar
C5 Diag
Don’t worry you won’t get electrocuted !!…as long as you leave it in it will continue to crank…I have 2 ways to test relays…much prefer the “U Activate”…just flip the switch…if still clicking I would replace starter with the new solenoid.
Old Dec 26, 2024 | 02:16 PM
  #44
turnerg1's Avatar
turnerg1
well not electrocuted but a nice burn. Charred the end of the paper clip.
Gonna try with pliers this time.
So if it continues this hollow clang then the solenoid needs replacing? Do they come separate from the starter or a combo?
Greg
Old Dec 26, 2024 | 02:29 PM
  #45
C5 Diag's Avatar
C5 Diag
You can probably find the solenoid but if were ME I’d be replace the whole thing…you can find a few on Rock Auto anywhere from $58.79 to $280.79….all are remanufactured though…you can try NAPA also…stay away from Amazon or EBay as a majority of their parts are counterfeit !!
Old Dec 26, 2024 | 02:43 PM
  #46
turnerg1's Avatar
turnerg1
thanks. About to order the ac delco from rock auto.
Good times
Greg
Old Dec 26, 2024 | 02:58 PM
  #47
C5 Diag's Avatar
C5 Diag
While you’re down there I’d clean ALL the wiring down there until they are bright and shiny and also remove G106 which is the battery negative block ground and clean that too…won’t hurt to clean the engine block at G106 also.
Old Dec 26, 2024 | 03:03 PM
  #48
turnerg1's Avatar
turnerg1
yeah since I'll have to remove everything to get it out I'll clean all the connections. Glad I bought the quick jack.
Greg
Old Dec 27, 2024 | 03:03 PM
  #49
turnerg1's Avatar
turnerg1
while I'm waiting on my starter to arrive I'd be interested in any theories.
I put the paper clip jumper in first time and it cranks.
2nd time the loud hollow clang and sparks fly from the relay slot and paper clip. havent retried since.
I'm thinking on it when the car does crank there is no clang. Only on the attempts to start and nothing happens do I get the clang and then it's only the first time. The remaining attempts no clang, no crank. Until it does actually start and it's usually a good start. don't notice a clank.
Any thoughts there.
Greg
Old Dec 31, 2024 | 10:27 AM
  #50
turnerg1's Avatar
turnerg1
Before I go tearing into this starter plug how does it pop off.
yellow plug with green cap
Old Dec 31, 2024 | 10:48 AM
  #51
C5 Diag's Avatar
C5 Diag
On that one you should have to stick a small screwdriver and separate that tab seen at the bottom to release…that slot is where the connector locks onto…and clean the body ground and the other 2 !!…if you have a 12 volt battery laying around you can test that starter.
Old Dec 31, 2024 | 10:57 AM
  #52
turnerg1's Avatar
turnerg1
ok just pops out.
However look what happened when trying to remove the nut for the power connector. Shattered at the slightest of turning.
Good times.
Old Dec 31, 2024 | 10:59 AM
  #53
C5 Diag's Avatar
C5 Diag
That stuff breaks after 20 years !!…looks like a good old Delco Remy OE starter.
Old Dec 31, 2024 | 11:40 AM
  #54
turnerg1's Avatar
turnerg1
started right up no issues. Now for a drive
Old Dec 31, 2024 | 11:42 AM
  #55
C5 Diag's Avatar
C5 Diag
Great !!…did you clean up all the wiring ??
Old Dec 31, 2024 | 12:25 PM
  #56
turnerg1's Avatar
turnerg1
yep. All good. thanks for all the guidance.
Now to my next gremlin. The sony aftermarket head unit a previous owner installed works but the clock changes time randomly (several hours randomly) and right now stays about 30 mins off.
more investigating.
Greg
