Shifter indicator issue
Old Feb 6, 2025 | 04:13 PM
jvas201's Avatar
jvas201
1st Gear
Default Shifter indicator issue
I have a 2011 c6 (auto) and the shifter indicator is not working correctly. When I shift down into "reverse" down 1 click it is in reverse but the orange indicator is not showing in reverse and the reverse lights will not come on. I click it down half a click in then the indicator is over "R" The car goes into gears just fine with no problem. It almost seems like the indicator is lose of some sort. I have taken the shifter apart and everything looks fine. Any ideas as to what it could be or what could be causing this issue.
