MechMan 170 Charge Cable Question
Old Feb 17, 2025 | 11:49 PM
AllnattyZ06's Avatar
AllnattyZ06
6th Gear
Default MechMan 170 Charge Cable Question
Car is currently at the builder, I want them to install a MechMan 170 when they reassemble the engine.
Can this be installed without upgrading any charge cables or grounds?
I plan to change them out myself once the car is built, dyno’d and returned to me.
Old Feb 18, 2025 | 09:45 AM
pdc001's Avatar
pdc001
I would have the shop/builder at least run a single larger gauge wire from the alternator side at least if you want it to look OEM since it runs behind the engine block with that wire loom.
If the engine is coming out that would be the easiest time to replace that particular cable because it runs to the starter which makes it annoying to deal with the engine assembled back in.
Is it necessary, no but it'll make the installation look cleaner and that'll be the time to do it.
Old Feb 18, 2025 | 06:39 PM
TTZ06VETTE's Avatar
TTZ06VETTE
Not really necessary unless there is an issue with stock cable. Been running this alternator with stock cable and a ton of heat from turbos on my application for 10 years now without issue.
Old Feb 18, 2025 | 07:01 PM
gsflyer2011's Avatar
gsflyer2011
I am runing Mechman170 amp alt for over a year, using stock setup and wiring, no problems whatsoever. Works like a charm.
Old Feb 19, 2025 | 06:24 PM
Dzv69's Avatar
Dzv69
When i decided to go with the Mechman 170 on my 2012 Grand Sport (rear mount battery) ,
i also had my mechanic install this Hot Start Kit (Full Remote)---> C5/C6 Corvette Hot Start Kit — SMGspeed
  • The Under hood kit replaces the block ground, starter and alternator wires.
  • The Full kit includes all of the above- along with a full length lead for rear mounted batteries and/or z06/grand sports. As well as a battery ground
Old Feb 20, 2025 | 10:03 PM
MannyS's Avatar
MannyS
same answer for me. No changes made after installing a Mechman 170 eighteen months ago. Zero issues.
Old Feb 20, 2025 | 10:21 PM
AllnattyZ06
6th Gear
Appreciate the feedback on this. Thank you
Old Feb 21, 2025 | 08:24 AM
double06's Avatar
double06
I think when you get to the 250 amp version they recommend the upgrade.
To MechMan 170 Charge Cable Question
