Codes & Engine running rough
Old Mar 13, 2025 | 11:32 AM
leebay's Avatar
leebay
Default Codes & Engine running rough
2012 GS, auto, 6k miles ,with engine light flashing, traction control light, service traction system, service active handling system, engine running rough. I disconnected the battery and codes came back on. Car running fine yesterday all plug wires Intact. Please advise Thanks
Old Mar 13, 2025 | 11:42 AM
PMPerformance's Avatar
PMPerformance
Did you run the codes?
Old Mar 13, 2025 | 11:46 AM
C6ToGo's Avatar
C6ToGo
Unless you can provide this audience with the troube codes that your car has generated and stored, I am going to guess..........BAD GAS.
Old Mar 13, 2025 | 11:54 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
A flashing MIL is a cat damaging misfire so you want to get this repaired ASAP if it returns…the TC light and service TS will also illuminate…if this is intermittent and you don’t have the knowledge and advanced diagnostic equipment to handle this find a shop who has this equipment…other than plugs and wires a DIY’er will just waste time and money on the fix !!
Old Mar 13, 2025 | 12:46 PM
leebay's Avatar
leebay
No , will be tomorrow hopefully
Old Mar 13, 2025 | 12:47 PM
leebay's Avatar
leebay
100% gas and Techron added 12-24
Old Mar 14, 2025 | 06:00 PM
leebay's Avatar
leebay
Code reader shows cylinder #2, tech did a quick check said its not the coil so either a dead fuel injector or a broken valve spring. Will have towed to his shop.
Old Mar 14, 2025 | 06:03 PM
C5 Diag's Avatar
C5 Diag
These are the things that may cause a misfire so I wouldn’t say it’s an injector or valve spring unless they test….
  1. Plug
  2. Wire
  3. Coil Pack
  4. Coil Pack wiring
  5. Fuel Injector
  6. Fuel Injector wiring
  7. Fuel Injector wiring- bad ECM/PCM
  8. Valve Spring broken
  9. Burned Valve
  10. Cam Lobe worn
  11. Low Compression- Rings
Old Mar 14, 2025 | 10:35 PM
08z51m6Ls3's Avatar
08z51m6Ls3
Do you have longtubes?
I had the same issue. Was throwing codes intermittent misfire as well as traction control / stability.
ended up being a fried 02 sensor wire. It was laying against the exhaust and burnt through causing a bad misfire.
Old Mar 15, 2025 | 01:45 PM
leebay's Avatar
leebay
No longtubes. Car is completely stock.
To Codes & Engine running rough
