LS2 with LS3 Top end
Here is what they offer:
"I could have you a pair all done up, that’s with a fresh valve job, resurfacing bead blasting, new intake valves, resurfaced and bead blasted original gm exhaust valves and the btr .660 titanium retainer spring kit"
Now what I'm not sure about is what kind of compression will I end up with if I tell them to mill the head and by how much? I see most people with this setup running .040 head gaskets but what kind of compression will that get me exactly since the LS2 has more compression than an LS3 from factory.
I'm also worried about valve-to-piston clearance. I am told I should have room for 240* @.050 range but I really don't want to go too aggressive on the cam since I plan on supercharging down the road. Once I supercharge it, I would lower the compression but for now, I am looking to have as much as possible.
Lastly for the electrical portion. I plan on getting a complete LS3 intake manifold with injectors and fuel rails and use my silver blade LS2 90mm throttle body. Is an LS3 MAP sensor with an adapter harness all I need? I also plan on getting a harness to use a card style MAF.
I would NOT have the heads shaved any as you want to lower the compression especially if you will be supercharging. LS2 is already a bit on the high side with a 10.9 CR. Going to an LS3 top end should lower it to about 10.7.
LS3 821 heads have 69cc combustion chambers. 823 heads 70cc. Either would work fine. 823 heads would lower CR a little more than the 821's.
And I would choose an appropriate cam. If you will be supercharging, get a cam for that application. You can run it perfectly fine until you supercharge.
What is the application for the car? Race car, weekend drag strip, street strip, fun car/daily driver? And is the car an auto or manual?
I'd look for a cam with intake duration in the mid 220's, exhaust duration in the mid 230's, with a 115 or 116LSA. Lift in the low .600's. Good power potential without many, if any, big cam demons.
I think I will just get the 102 to pair with my 1 7/8 long tubes, change my valve springs with a mild cam and save the rest for the supercharger.
My Ls2 made 580 whp (A6) with just a set of shorty headers and an electric water pump.
Just seems like you're taking the long way around jmo
You have the long tubes already? -so less than 5k US but either way I'd go straight to supercharger and see where you're at and go from there, again jmo based on your hp goals.
