Dashboard clusters paint flaking
Old Apr 4, 2025 | 05:12 PM
Renevette1982's Avatar
Renevette1982
Default Dashboard clusters paint flaking
I know this issue is mentioned a lot but i have seen no solution yet.
The paint of the ***** of my dic and hud **** clusters on my 2005 are flaking off. Did anyone tried to repair them instead of replacement?
Old Apr 6, 2025 | 05:35 AM
Renevette1982
Nobody ever tried to fix them?
Old Apr 6, 2025 | 06:41 AM
Dano523's Avatar
Dano523
To get to the pods to remove them,
Originally Posted by RicK T
You have to at least undo the cluster so you can get to the 3 screws that hold the pod. Info and pics at the beginning of this DIY:
http://forums.corvetteforum.com/c6-c...many-pics.html
And for replacement pods, $200 will get you both sides new, or half that price for used ones that the paint is not flaking/worn off,
GM 10363918
GM 15285915
As for repainting, can be done, but would need to first remove the paint on the bottons since its flaking, then laser cut emblems to cover the non painted areas that do allow the light to shine through, so they can be resprayed with paint.
Old Apr 6, 2025 | 07:42 AM
Renevette1982
I understand that buying them new is the best option if they are not that expensive.
But i have seen posts of flaking pods from late model C6's so are the newer pods any better?
If my problem is solved with 200-250$ i would gladly buy new, but are they available and will they not show the same issue in a short time?
To Dashboard clusters paint flaking
