Automatic Transmission Venting Fluid
Old Apr 19, 2025 | 05:23 PM
Hawkdriver's Avatar
Hawkdriver
Default Automatic Transmission Venting Fluid
What would cause automatic transmission to vent fluid? I used the proper filling procedures…twice. Replace filter probably a year ago. It is coming from vent tube. Getting ready to pull the exhaust and check the filter. Can you put it on incorrectly or if you use different fluids maybe cause a foam? Drives fine
Old Apr 19, 2025 | 08:52 PM
Aardwolf's Avatar
Aardwolf
Over heated or over full are my first thoughts.
Old Apr 19, 2025 | 09:03 PM
Hawkdriver's Avatar
Hawkdriver
Yep. That’s what I thought when it started about 6 months ago. Does it pretty much however I drive it. Just checked the level and it’s low but still does it after making sure it’s correct. Just dropped the pan. Not sure if I should be looking for something in particular. Going to change the filter again
To Automatic Transmission Venting Fluid
