KB Boost A Pump
Old Jun 11, 2025 | 01:33 PM
Rino1425's Avatar
Rino1425
Default KB Boost A Pump
I was going to order the KB Boost A Pump but from what the site says it really only works with Fords. I have seen other people talk about putting them on the C6, but is it still plug in play or am I going to be doing a lot to splice wires etc?
I plan on also getting the Racetronix set up too
Old Jun 11, 2025 | 04:19 PM
DarkC-6's Avatar
DarkC-6
Works great on a C6 and you've made a wise choice to also get the Racetronix harness. You should really only have to add the weatherpak connectors to 2 wires.
Old Jun 11, 2025 | 05:32 PM
Spaceme1117's Avatar
Spaceme1117
It is not quite plug and play but very close.
The Racetronix fuel pump rewire is excellent. Racetronix also makes a small and cheap connector kit for a nice oem install of the BAP with the Racetronix harness.
Old Jun 11, 2025 | 06:30 PM
Dano523's Avatar
Dano523
Boost a pump, just sends higher voltage to the fuel pump, to spin it faster, so it produces more pressure and volume, but shortens the life of the pump as well.
So better to just install higher volume/pressure fuel pump from the start, since at some point with over driving the stock fuel pump to cook it faster, will need to replace it anyways
As for plug and play, not in the sense that your going to reuse the fuel pump wire from the engine fuse box to pump to send the higher voltage (will melt/burn up that wire), but instead the aftermarket harness is going to have it own larger gauge wires to come off the fuse box terminal, through it relay, to the fuel pump connector above the tank, with the old fuse box wire for the pump, only controlling the relay now.
Old Jun 12, 2025 | 08:29 AM
double06's Avatar
double06
You could also maybe figure out how to trigger it when only a WOT. No point in boosting the voltage while sitting at stop light. This will help the pump last longer.
Old Jun 12, 2025 | 08:36 AM
DarkC-6's Avatar
DarkC-6
That is exactly how it works. It uses a hobbs switch to only boost the voltage when needed, i.e. when you hit 3-4 psi of boost. For this reason I doubt it has any significant effect on the life of the fuel pump.
Old Jun 12, 2025 | 01:36 PM
Rino1425's Avatar
Rino1425
Yes, this was my understanding of it that it only kicked on when you were at WOT, the rest of the time it would be just the normal fuel pump pressure
Old Jun 12, 2025 | 01:39 PM
DarkC-6's Avatar
DarkC-6
To be clear it's based on boost pressure, not throttle position. I can go WOT under 3k RPMs and there will be almost no boost yet so no need for the pump booster to operate.
Old Jun 12, 2025 | 01:41 PM
Rino1425's Avatar
Rino1425
Perfect, thank you for that info!!
To KB Boost A Pump
