Torque Converter….worth it?
Spoke with Yank today and they said their billet 9" 3200 stall converter would cure my pushing issue. The down side they are a touch over $1100 plus install.
I've done two C6s the owners are friends. They race each other, both have the same, same headers, same year, same gears, same tuner, they make about the same power +/- 5, depending on the dyno pull. One has a stock converter, and one has an aftermarket converter. They both drive pretty well. The aftermarket converter car feels a little better to drive, and it's quicker. Every race ends the same they take off, and the converter car jumps out about 1.5 cars, and then they hold that spot the whole time.
The key is getting the right converter for the car. I've gone from running high 10s to low 10s in my c6 with only a converter swap. One of my friends didn't want to get a "loose" converter for his cammed ls3, he ended up getting a "2800" and the car had a slower 60ft than it did on a stock converter, it drove decent, but it couldn't get it to the power band right. We ended up going to a looser converter, and that car drives so much better now and dropped almost a whole second on the 1/4 in similar conditions.
Here's a video I did to try to show a real world difference between a stock converter and an aftermarket converter.
It can make or break any combo.
I only use triple disc Yank anymore in V8 applications. Most of my customers prefer to stay in lockup cruising onthe highway when transitioning to wide open throttle, there are many benefits to triple disc in this way.
The cons to a quality converter are few, but here
-slight decrease in fuel economy out of lockout , barely noticeable on some vehicles though.
-Very expensive part is at risk if anything happen to the trans = trans + converter are both taken out.
I generally recommend get a transmission built by Dana at probuilt or Clinebarger before spending the coin on a quality converter from Yank. This has been a proven combination for 20+ years.
