Alternator Options
Old Jun 25, 2025 | 09:24 AM
RoadkingC6's Avatar
RoadkingC6
Default Alternator Options
Hello, looks like it's time to replace the alternator in my 2005 Base Vette, i looked at Rock Auto and they show several new Alternators GM, Valeo, Denso and WAI Global. They are all 145 amp, the GM new not rebuilt is the most expensive, but also the only one to show the voltage output as 14 volts the others show the output at 12 volts, I thought all alternators put out 14 volts, i'm leaning towards the GM alternator the price is $412.00 plus tax and shipping, the price difference is around $50.00 higher than the others not a huge difference but i was wondering if anyone has suggestions on which they would go with, also the tensioners and belts were replaced last summer.
Old Jun 25, 2025 | 10:18 AM
djfury05's Avatar
djfury05
If you're going to spend that much you might as well get a Mechman 170 amp and improve the whole car's electrical system. I love mine, never any voltage drops now.
https://www.mechman.com/s-series-bil...lack-anodized/
Old Jun 25, 2025 | 10:35 AM
abc63's Avatar
abc63
Yep, Mechman all the way and don't look back.
Old Jun 25, 2025 | 11:15 AM
RoadkingC6's Avatar
RoadkingC6
I was just on the Mechman site,they say there's no clutch on their alternators and there may be a minor squeak when you shut the car off but it's hardly noticeable and has no effect on performance, how noticeable is the squeak? the price for the S170 is $467.10 so your right it's just a little more than a GM New Unit.
Old Jun 25, 2025 | 04:12 PM
baxsom's Avatar
baxsom
Get the mechman from Brett here. His company specially builds them to match with the corvette charging system and they don’t need a separate ground wire
Old Jun 25, 2025 | 05:03 PM
Dzv69's Avatar
Dzv69
Another recommendation for the Mechman 170. I have one on my 2012 Grand Sport manual trans, love it !!!
Old Jun 25, 2025 | 05:58 PM
DSOMC6's Avatar
DSOMC6
Mechman paired with Sac City Big 3 has worked excellent for me.
Old Jun 26, 2025 | 02:08 AM
Dano523's Avatar
Dano523
Read, since problem may be easy fix with a new set of brushes for a few dollars if they are just worn out, or even free if problem is brush housingsare packed with debris and brushes are just binding and quick clean up of slip rings isntead,
https://www.corvetteforum.com/forums...nator-fix.html
If push comes to shove, rebuild kit for new brushes/new slip ring are less than $10, and regarding the bearings most of the time still in great shape/just need to be re-greased. The voltage regulator, unless you where using the alternator as a welding, it will be fine, and just need to clean up its and body contact points.
Short of that, and have upgraded stereo with amplifiters pulling more power, or just have to run the HVAC in stop and traffic, then look into the mechman 170amp billet alternator.
The Oem Valeo alternator puts out about 14amp at idle (radiator fan pulls 18 amps when running) while the mechman billet with twice as many poles, put out over 45+ amps at idle isntead. Hence problem is not so much the max that alternator can put out full tilt, its all about what is can do when motor is just idling instead.
To Alternator Options
