Need advanced RCDLR troubleshooting help
A couple of key things.
- Multiple new batteries in the fobs installed correctly and tested with a RF fob tester
- The fobs always work in the glove box slot
- New car battery and on a tender
- When I disconnect the battery for a while, touch terminals to be sure and hook back up, the fobs will sometimes work, but more often than not they wont be detected.
- When the car detects the fobs everything works as it should, all buttons, door latches, ignition.
- Even though they looked shiny and good I reflowed solder on the RCDLR header pins. Connecter pins on the RCDLR looked corrosion free but hit them and the plugs with Deoxit. I redid G104 ground (RCDLR) and G202 (BCM). After I did this after multiple failed battery reconnects, it finally did and stayed connected for a week then were not detected (car was sitting in the garage, no maintainer, battery voltage dropped to 12.2V). Previously when I got the fobs to be detected they'd lose communication after a few hours at the most.
- Dano has been helping me via PM and had me fiddle with the splice by the amp in the pass side footwell.
No DTC for the RCDLR but checked voltage with the tech 2 and see 11.89V. I hot swapped the spare RCDLR and the tech 2 then said 12.09. Oddly by swapping the module back, the fobs were detected but intermittently "no fobs detected" popped up.
I probed the RCDLR connector for voltage and circuit 2440 "Battery positive voltage" read 12.4V, Circuit 3, "Ignition 1 voltage" reads 0.05V idle, it jumps up very briefly with ignition switch activity (maybe it briefly jumped to ~12v but my meter cant keep up). I used the connector ground and chassis ground (shifter nut) and got the same readings so I assume I can rule out a bad ground.
At the battery terminals on the tender the battery measures 13.03V
Fuse 11 that feeds the circuit 2440 "Battery positive voltage" reads 12.94V
- 11.98V @ the RCDLR on the Tech 2 seems like a problem especially since it seems these modules are finicky about voltage, but 12.4v @ the RCDLR plug when the fuse reads 12.94V seems like a lot of drop.
- Is Circuit 3 "Ignition 1 voltage" just a momentary signal? Would explain the blip in voltage when pressing accessory. Odd that it has a low 0.05v residual voltage.....
I can't find CKT 2440 on the master splice list, so I guess this means no splices between the RCDLR and fuse connector for the battery positive?
I couldn't probe D11 at fuse box c3 because of the way the harness works so I pulled the box off the connectors and checked resistance from the fuse block to the RCDLR connector and measured .5 ohms. I then put battery + to pin D11 and measured voltage at the RCDLR connector (unplugged) and got the same as battery voltage. Fuse 11 also showed the same as battery voltage (before I took the fuse box off of course).
I didn't see any corrosion or anything funny on the fuse box connectors but sprayed both male and female with Deoxit and put it back together. Now Fuse 11, pin H at the RCDLR measures the same as battery voltage. Perhaps there was a bad contact in the fuse box. Tech 2 still says the RCDLR voltage is high 11's though.
I reconnect the neg terminal and the fobs are detected. I undid the battery negative touched terminals 2 more times and fobs were detected just like they should. Before when I was troubleshooting it would take a few attempts before the car detected the fobs. Wish I found a smoking gun but this seems to be better than where I was and the voltage drop I had at the RCDLR could explain.
The circuit 3 ignition 1 voltage I tested was pin c on the RCDLR connector 1. When I pressed the ignition to put it into accessory the volt meter jumped up quickly but immediately dropped, like it was just an instantaneous energize not switched on.
- DVM between Pos post and Fuse 11 0.009v
- DVM between pos post and RCDLR pin H 0.013v
- DVM between Neg post and RCDLR pin S 0.011v same when I test J ignition mode ground.
I do not know how to do a terminal tension/pin drag test.
Battery is at 12.64V and Tech 2 still shows the original RCDLR voltage at 11.98v. If I swap the used one I was going to program the tech 2 says 12.2v car off 12.09 in accy. Is there risk in trying to program the used RCDLR and see if it helps? OR is 12.09 still an issue?
When I check voltage at RCDLR pin C Ignition 1 voltage (DVM on neg post) I get ~0.057v either off or in accy (didn't try to start the engine as I cant). Should this behave like a switched circuit on a radio, hot in accy and run? Interesting that it has a Ignition 1 voltage and an ignition mode data signal circuit.
I tried looking to see if I can find BCM voltage on the tech 2 but couldn't but did find 3 BCM DTC's U2108 lost comms with ABS/TCS, B1325 Dev Power 1 circuit voltage below threshold & B0006 in park switch circuit. I cleared them then read them again and none came back......
Device power 1 circuit low, perhaps low voltage to the BCM?
Battery feed & ground at the RCDLR test good.
Ignition 1 volts at the RCDLR measure only 0.057v but since my problem is when the car is off, not sure if that is an issue (yet).
I bought a used RCDLR but have not tried programming it yet. When I hot swap to the unprogrammed RCDLR volts on the Tech 2 go from high 11's to low 12's.
So can you get the ignition ON ??...green start light on holding the bottom of the start button down for 5 seconds...that is normally how you get these ignition circuits to work...to get the run/crank relay energized that must be done.
Although my issue is with the car off I did check "ignition 1 voltage" and get .057v car off, .066v in accessory and .13v when on after I push the bottom of the start button for 5 seconds. I would have thought it behaved like a switched 12v but maybe that's how its supposed to work. I can't find much info on this.
I pulled the C4 connector and everything looked good.
Considering I saw minimal voltage drop on the battery and ground circuits between the RCDLR & battery, I'm going to put the car on a charger and attempt to program that used RCDLR I bought.
With help from Mike Schneider's youtube vids I installed my ebay RCDLR, invalidated all fobs, learned my 2 fobs which worked fine all but engine crank. Then followed the 3x routine where I attempted to start the engine, left the car on for 10 mins when the security light went out and on the 4th time it fired up.
Seems too easy. I thought I was going to have to program in the new module with the Tech 2 (was getting a "controller locked" message). Perhaps the 3x 10 min cycle could have been expedited by just going in on the tech 2 to accomplish the same thing?
