Harmonic Balancer replacement
Old Jul 13, 2025 | 09:54 AM
KRS's Avatar
KRS
Default Harmonic Balancer replacement
Is the replacement of choice still the ATI? The only thing that concerns me is according to the FAQ's on their website it says they need to be removed and sent in to rebuilt every few years
Old Jul 13, 2025 | 10:45 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
You posted in Detailing section, moving you here for assistance.. good luck
Old Jul 13, 2025 | 10:46 AM
KRS's Avatar
KRS
Thank you!
Old Jul 13, 2025 | 10:55 AM
schizcat's Avatar
schizcat
Depends what the end goal is. Most use ATI or Powerbond. Cost is a factor as well. As for the ATI being rebuilt, they do require it if it's under high load ie power adder. I think for daily or infrequent driving, you may need it rebuilt but at a longer interval. No actual experience with ATI as I used a PB.
Old Jul 13, 2025 | 01:36 PM
KRS's Avatar
KRS
so you have had good success with the Powerbond then?
Old Jul 14, 2025 | 04:21 PM
Orion2011's Avatar
Orion2011
Technically all HB's should be replaced every 10 years. ATI can be easily removed and rebuilt where others can't. Though in a street application it's probably fine not having it rebuilt every 10 years.
Old Jul 14, 2025 | 07:01 PM
schizcat's Avatar
schizcat
I have. It's been on since 2017. Caveat is that it's not a daily any longer. I've put 5-6k miles on it since replacement
Old Jul 15, 2025 | 08:45 AM
KRS's Avatar
KRS
How are they easier to remove and repair than any others? you still have to drop the steering rack etc to get it off
Old Jul 15, 2025 | 11:05 AM
Orion2011's Avatar
Orion2011
ATI unbolts from the pressed on hub portion. Not sure since I don't own a C6 anymore but I think you cant take that part off without dropping anything. Again you press on the hub then bolt the balancer to that. Most are all one piece.
Old Jul 15, 2025 | 11:29 AM
Pettrix's Avatar
Pettrix
ATI balancer and pin it to the crank. Case closed.
Old Jul 17, 2025 | 09:55 PM
JL3100AD's Avatar
JL3100AD
If you don't care about performance upgrading then a cheap powerbond is fine. I chose ATI on my build, not worried about a "rebuild". My toy car will never be used enough to need a rebuild as most of these corvettes on this site.
To Harmonic Balancer replacement
