Help... Lol
Old Aug 7, 2025 | 08:13 PM
Eli-Z06's Avatar
Eli-Z06
Default Help... Lol
Does anyone know what this is for, and can I delete it so I can clean up the engine bay
Old Aug 7, 2025 | 09:41 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
That is your EVAP purge valve and no you can’t delete it…you won’t pass your yearly inspection without it.
Old Aug 8, 2025 | 07:55 AM
double06's Avatar
double06
I thought that was more hidden out of the way did you have to move it because of the vacuum pump?
Old Aug 8, 2025 | 08:15 AM
Eli-Z06's Avatar
Eli-Z06
I don't have EPA emission testing out here in Pa. Has anyone deleted it with out any check engine light...
Old Aug 8, 2025 | 08:44 AM
C5 Diag's Avatar
C5 Diag
If you delete it the check engine light WILL illuminate…you will need someone with HP Tuners to have the MIL not illuminate or set a DTC.
Old Aug 8, 2025 | 08:49 AM
Eli-Z06's Avatar
Eli-Z06
Okay thanks. I'm going to have to look more into this before I do anything. I appreciate it
Old Aug 8, 2025 | 11:59 AM
Aardwolf's Avatar
Aardwolf
It's easy to cut it back so it's just on the driver's side and not crawling across the throttle body.
Old Aug 8, 2025 | 12:23 PM
Eli-Z06's Avatar
Eli-Z06
Yeah 10-4 I just noticed that I'll shorten it up and clean it up. Thank you
Old Aug 8, 2025 | 01:39 PM
Aardwolf's Avatar
Aardwolf
Old Aug 8, 2025 | 04:33 PM
Eli-Z06's Avatar
Eli-Z06
Oh yeah that looks much better. Thank you...👍🏻👊🏻
Old Aug 8, 2025 | 05:50 PM
double06's Avatar
double06
Looks like you could even make a little bracket by alternator and mount it there.
Old Aug 8, 2025 | 08:24 PM
Aardwolf's Avatar
Aardwolf
I polished the tb after that. Then installed a fast and the fuel cross over goes over the tb doh! I tried it in back and it hits firewall.
Old Aug 10, 2025 | 04:17 PM
PMPerformance's Avatar
PMPerformance
What county are you in that doesn’t do emissions testing in 2025?
Yes you can remove them in general. I’ve done it on other cars. I am sure you will get a code
though.
Why do you want to remove it though exactly?
Old Aug 14, 2025 | 11:03 AM
DarkC-6's Avatar
DarkC-6
though.
Most counties in the US do not have any type of emissions testing.
Old Aug 14, 2025 | 11:43 AM
PMPerformance
I did not realize that 42/67 counties in PA still do not require this. I guess not all counties care about the environment. Lol
Moving to one of those counties is in my future.
Old Aug 14, 2025 | 11:52 AM
Eli-Z06's Avatar
Eli-Z06
Default Emissions and e85
So out here in PA E85 is regularly available and the car does not have any smell or smoke. Runs nice and cleane and obviously makes more power! 👍🏻👊🏻🏁🏁
To Help... Lol
