St. Jude Donor '12-'13
Vararam transmission cooler advice
The vararam was on the car when I bought it, then I added a bunch of mods including a 3600 and a stacked plate trans cooler which was fine back in Illinois.
I since moved to Arizona and upgraded to a Dewitts radiator which keeps the car between 200 -210 when its 110+....problem is the trans temps get north of 200 in traffic. Looking at where the cooler is placed isn't ideal as the vararam is basically blocking the flow past it.
Also wondering if the shroud is hacked up incorrectly as well. Wondering if anyone else has dealt with this, and what the solution was? Different air intake? Reworked shroud? A fin style cooler? Not sure where else to place the current cooler.
Update:
Pulled the vararam off the car. Pulled the hacked up radiator shroud off as well.
Was able to order a new shroud from GM and went with an AFE air intake setup. Installed everything today and the issues have been resolved, even in the triple digit heat with the AC on.
