Radio replace
Old Aug 12, 2025 | 11:59 AM
slavo_s2k's Avatar
slavo_s2k
Default Radio replace
I want to replace the radio in my 2008 Corvette base. If I buy another one from the same year, will it fit (I understand that I need to add the VIN to the radio using Tech2), or is it not that simple?
Old Aug 12, 2025 | 07:38 PM
jamieo's Avatar
jamieo
Straight swap,then TechII to VIN match it.
Old Aug 12, 2025 | 07:54 PM
PMPerformance's Avatar
PMPerformance
Why replace with another stock radio?
Not sure on your year, but some years you need programming to unlock to your car.
Old Aug 14, 2025 | 10:20 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Why swap with another GM radio when there so many on the market with camera's, bluetooth and apple play, all are plug and play without using tech II to make them work lot better then GM radio's, I don't recommend when your phone has Waze much better GPS always updated to the latest maps.
Old Aug 15, 2025 | 07:11 PM
slavo_s2k's Avatar
slavo_s2k
I know that replacing the radio with a GM one again might not make much sense (the current one broke), but I don’t necessarily want to do major modifications — other radios aren’t completely plug-and-play and require adapters.
Old Aug 15, 2025 | 07:22 PM
Dano523's Avatar
Dano523
Straight swap, remarry with Tech 2, but what is wrong with the radio in the car now, since may be an easy fix, and a lot cheaper that replacement unit.
Old Aug 15, 2025 | 07:27 PM
slavo_s2k's Avatar
slavo_s2k
A fault in the radio’s electronics — it only works when I warm it up or after driving the car for a while. I tested it when the radio was cold and it wouldn’t turn on — I heated it with a hair dryer and it started working A friend has a working original GM radio for $100, so I think that will be the cheapest repair option.
Old Aug 15, 2025 | 09:54 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
This company sells radio's and Plug & Play harness for your car I don't know if they ship out of country.
https://www.crutchfield.com/S-vTiZaH...r-Stereos.html
Old Aug 16, 2025 | 03:16 AM
slavo_s2k's Avatar
slavo_s2k
Cool site, thanks! When ordering there’s no option for shipping outside the US, so I sent them a message.
Old Aug 17, 2025 | 12:12 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
Keep us posted?
To Radio replace
