Cat Cleaners
Old Oct 19, 2025 | 03:51 PM
KonaBlue's Avatar
KonaBlue
Default Cat Cleaners
My06 C6 was throwing a 430 Cat Sensor Code. I replaced the rear (outbound) O2 sensors and the code continues. I am wondering if anyone has tried the Cat Cleaners available on the market and if they are ok to use to alleviate the problem without changing the cats. Car runs great....just check engine light is annoying. Thank you for your thoughts.
Old Oct 19, 2025 | 04:42 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I just responded to your other post...could be things other than a bad cat...that stuff is just "snake oil".
Old Oct 19, 2025 | 06:23 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
If you go to any muffler shop they can check it out may putting it up on a lift with engine running they use thermometer to measure how hot your Cat is, when my was throwing codes they found the right Cat over 400 degrees while left was less then 200 degrees.
Old Oct 20, 2025 | 03:12 PM
fat biker's Avatar
fat biker
SWAG?
Time to replace the cat.
Do not ask how I know.
To Cat Cleaners
