Cold Air Intake
Old Oct 23, 2025 | 11:50 AM
SCHOONERc6's Avatar
SCHOONERc6
Default Cold Air Intake
I'm looking for suggestions on Performance air intakes. 2008 base model C6.
Old Oct 23, 2025 | 08:23 PM
TucoTom's Avatar
TucoTom
The stock air intake on the LS3 isn't bad, aftermarket intake around $600 and not much gain for the money.....
I did go with the Attack Blue filter over the factory.
Old Oct 23, 2025 | 10:04 PM
BadAV's Avatar
BadAV
Halltech Hurricane or Vararam if you are going to do it. Not needed on a stock engine.
Old Oct 24, 2025 | 11:03 AM
vms4evr's Avatar
vms4evr
I'm with you. I spent $100 for the aFe power magnum flow filter (found on Amazon). Reusable just like K&N. Maybe get a smooth coupler for the connection to the Tb. Other than that airflow is more than enough for a stock motor. Put that extra money into something you can enjoy more.
Old Oct 25, 2025 | 10:01 PM
tebrules's Avatar
tebrules
go on youtube. they compare intakes on ls3's. like Tom said you will get little gain, and if you do the mods to the stock
one, it will be even better than some costing $1200.
Old Oct 25, 2025 | 10:03 PM
tebrules's Avatar
tebrules
oops, that was for intakes, not cai's. sorry. youtube videos to make your own cai's as well though
Old Oct 26, 2025 | 08:17 AM
Spaceme1117's Avatar
Spaceme1117
Halltech Killer Bee MF103 will be your best aftermarket CAI but is pricey.
You can get the same performance by getting a used Z06 intake and installing a shroud Generic Beehive™ Heat Shield and cut it to fit the stock intake. Pretty easy to do. Make an identical shroud out of cardboard. Cut it to fit. Then use that as a template to cut the actual shroud.
The power gains come from preventing the engine from sucking is hot engine bay air.
Old Oct 26, 2025 | 04:11 PM
Dzv69's Avatar
Dzv69
Halltech makes a pre-cut heat shroud that fits the factory C6 LS3 air intake,
here is a link to the Halltech site:>>> Halltech GM LS3/7 Beehive Ram Air Induction Shroud
Old Oct 26, 2025 | 04:13 PM
Dzv69's Avatar
Dzv69
" preventing the engine from sucking is hot engine bay air" - does this only occur when the car is not moving, does the heat shroud have any benefits when the car is moving ?
Old Oct 26, 2025 | 04:21 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
The aftermarket performance air intakes are a good upgrade on Corvettes with the LS2 engine. Not so much for LS3s and up.
Tom
Old Oct 26, 2025 | 04:33 PM
Dzv69's Avatar
Dzv69
The same intake is used on the LS3, LS7 and LS9. If the OEM intake flows well enough for an LS7 and an LS9, certainly sufficient for the LS3
Old Oct 27, 2025 | 12:17 AM
sirdano's Avatar
sirdano
I got this too. The fit not that great but it works. also got a dry AFE air filter that can be washed not oiled
Old Nov 17, 2025 | 12:44 AM
Blast_off440's Avatar
Blast_off440
Does anyone think the fake hood scoop should be opened up and force air in the intake. My ls7 has a little slit in the bottom of the sub wall that leaks air to the intake, it's a joke really.
Old Nov 17, 2025 | 09:13 AM
sirdano's Avatar
sirdano
Can also do the free air mod
https://www.corvetteforum.com/forums...gle-bolts.html
Old Nov 19, 2025 | 12:06 PM
Corvettechris86's Avatar
Corvettechris86
I’ve noticed it directs airflow under that wall and into the filter area after i drilled holes for more airflow to the filter. The biggest benefit of a cai is reduced intake temps which in return gives you more timing and less knock retard. These engines start pulling timing and get more aggressive pulling timing as iat temps increase. Thats before any knock retard as well…
Old Nov 25, 2025 | 11:42 AM
ROCRAY's Avatar
ROCRAY
This past spring,I wanted to add a cold air intake to my ‘09 base model. After looking at a lot of aftermarket options, I choose the Halltech Killer Bee MF103. I basically picked this one because of the MAF sensor is relocated under the shroud to limit heat to the sensor. It seemed to make sense. Install was pretty straightforward. I’m very happy with this mod. Best wishes!
To Cold Air Intake
