tech2 capable shops in TX
Old Nov 7, 2025 | 03:03 PM
Jupiter81's Avatar
Jupiter81
Default tech2 capable shops in TX
so i am looking to disable a few things (mag ride and steering lock on 2005 c6) and at least on most local forums and chat i cant find anyone near San Antonio TX with a tech2 . . . willing to drive for sure to get it all done
Old Nov 7, 2025 | 03:49 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Never heard of a “Tech 2 Capable Shop”…any decent shop should have a factory level scan tool.
Old Nov 7, 2025 | 07:55 PM
Jupiter81's Avatar
Jupiter81
I'm not looking for a diagnostic work, i want to add my coilovers and needing to disable the FA45/55 so that i have no issue with the install. the same goes for the steering column problem, and i need a shop that has a tech2 so i can have those things disabled as a regular factory scanning tool isn't capable or so is my understanding of it
Old Nov 7, 2025 | 08:00 PM
C5 Diag's Avatar
C5 Diag
When I had my C5 I was able to disable my F45 with either my Tech 2 or my Autel factory level scan tool…anything I can do with my Tech 2 I can do with either my Autel, Snap On, or Launch scan tools.
Old Nov 7, 2025 | 08:31 PM
Skid Row Joe's Avatar
Skid Row Joe
Contact and join your Corvette local club for advise...
Old Nov 9, 2025 | 07:28 PM
baxsom's Avatar
baxsom
I worked at a Chevy dealership in Florida. We had one tech 2 scanner on a shelf and it never worked.
Old Nov 10, 2025 | 06:16 AM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
You can purchase new "clone" tech 2s for a couple of hundred bucks online. The one I got is in every way identical to my shop's (even came with the GM decals) and I suspect it was simply a leftover. They are not hard to use ...
-dj
Old Nov 11, 2025 | 05:45 AM
sirdano's Avatar
sirdano
Try Aikman preformance. I know they have one
Old Nov 11, 2025 | 12:02 PM
DarkC-6's Avatar
DarkC-6
-dj
This. If you use your Tech 2 twice it covers the cost over what a dealer will charge to plug it into your car for any reason. I first purchased my Tech2 to do a reset of the headlight leveling system on a Saab. I have since used it to reprogram BCM, reset fuel alcohol percentage due to a faulty virtual flex fuel measurement, activate ABS pump for brake bleeding, and various diagnostics and code-reading.
To tech2 capable shops in TX
