C6 Z06 Master Cylinder
Old Feb 25, 2026 | 01:48 PM
Trink's Avatar
Trink
Cruising
Default C6 Z06 Master Cylinder
I need to replace my master cylinder in my 2009 C6 Z06. The OEM is not available anymore.
I track my car abut 4-5 times a year, and I have been looking for a quality master cylinder. Wilwood does not make one for my car.
Does anyone have experience/knowledge of a quality master cylinder?
Old Feb 25, 2026 | 03:32 PM
99Hawk262's Avatar
99Hawk262
Rock Auto shows OEM available for 2009 Z06…$99
Old Feb 25, 2026 | 05:48 PM
Trink's Avatar
Trink
Cruising
Thanks very much! I am having difficulty finding the master cylinder on the Rock auto website. When I search by year/make/model, I can only find a master cylinder made by Dynamic Friction.
The OEM part number is 19432572, and when I search by that number, it says "no parts found".
Would you be able to send a link to what you found?
Old Feb 25, 2026 | 06:33 PM
99Hawk262's Avatar
99Hawk262
Try 19432063 for the part number. I’m not sure how to link, but that’s the part number they show.
Old Feb 25, 2026 | 06:53 PM
Trink's Avatar
Trink
Cruising
unfortunately that is for the Clutch. I am looking for the Brake Master Cylinder.
Thank you for trying!
Old Feb 26, 2026 | 06:44 AM
99Hawk262's Avatar
99Hawk262
My bad…you know what happens when one assumes! Posts about clutch MC’s pop up weekly and my brain immediately defaulted to that when I saw “master cylinder”. Your reference to Wilwood should have been a major clue-in, but alas, I missed that. Best of luck to you finding what you need!
Old Feb 26, 2026 | 08:54 AM
ClothSeats's Avatar
ClothSeats
I installed a new clutch master cylinder from Tick Performance in my 2006 Z06 last summer. Works well.
Sorry, after rereading this thread, it seems you are looking for a brake master cylinder, not a clutch master cylinder.
Old Mar 1, 2026 | 05:23 PM
ringram's Avatar
ringram
https://www.topflightautomotive.com/...08-base-06-z06
Ebay used...
Or rebuild?
https://www.applehydraulicsonline.co...IRvOPNLlxbsUSP
Old Mar 1, 2026 | 08:37 PM
Trink's Avatar
Trink
Cruising
Thanks for the info!
Old Mar 2, 2026 | 03:55 PM
KENS80V's Avatar
KENS80V
Your first link is for a 05 to 08 C6 Corvette. His car is a 09. GM switched to a Bosch supplied system for 09 to 13 cars.
Old Mar 2, 2026 | 04:13 PM
Trink's Avatar
Trink
Cruising
I noticed that also about the 05-08 link.
FYI for anyone who needs to replace the master cylinder for 2009-2013,
I located a replacement brake master cylinder made by Dynamic Friction. Part number 355-47110. At Rock Auto.
Old Apr 6, 2026 | 10:06 PM
JKNAPP's Avatar
JKNAPP
is it the same part # for the Z06 as well?
Old Apr 6, 2026 | 10:42 PM
KENS80V's Avatar
KENS80V
All models of 09 to 13 C6 Corvettes use Dynamic Friction 355-47110
I have a current Rock Auto discount code if you need it. PM me.
Old Apr 8, 2026 | 07:32 AM
JKNAPP's Avatar
JKNAPP
on my 08 Z06, the reservoir is just discolored (yellowed)
Old Apr 8, 2026 | 09:10 AM
Dreamer2's Avatar
Dreamer2
New part reservoir is black.
Old Apr 8, 2026 | 09:35 AM
KENS80V's Avatar
KENS80V
You can remove the reservoir from the body by knocking the pins out. Put some sand inside the reservoir with your detergent and shake it up. This should be enough to clean it internally. I have done this a couple of times now with various GM models including a C6 reservoir.
To C6 Z06 Master Cylinder
