TORQUE TO YIELD-ft.lbs then degrees??
Old Mar 14, 2004 | 10:38 AM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default TORQUE TO YIELD-ft.lbs then degrees??
Is this as easy as it sounds? I am assuming torque a bolt as per the chart then go (x) number of degrees to finish the tightening the fastener?? Maybe a slight explanation is in order for me.
Matt
Old Mar 14, 2004 | 09:13 PM
User 81424's Avatar
User 81424
Default Re: TORQUE TO YIELD-ft.lbs then degrees?? (6spd89)
Just torque to spec then recheck, no need to over-tighten.
Are you working on a C6?
Old Mar 14, 2004 | 11:03 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
I beleive that method is based on bolt stretch. It is superior in theory but not so easy to execute.
Old Mar 15, 2004 | 10:34 AM
WhiteDiamond's Avatar
WhiteDiamond
St. Jude Donor '15
Default Re: TORQUE TO YIELD-ft.lbs then degrees?? (need-for-speed)
Yes, based in the bolt stretch theory.
Try posting in a the C5 tech section, you will get more feedback. No C6s are out yet, so this the wrong section.
Todd
Old Mar 15, 2004 | 02:48 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Old Mar 15, 2004 | 05:23 PM
6spd89's Avatar
6spd89
No ,i have a 98. Just looking thru the torque specs and had neverseen that before. Thanks for the info .
Matt
Old Apr 11, 2004 | 01:18 AM
BHP's Avatar
BHP
You typically do an initial torque value with a torque wrench. Then you torque to the degrees in the shop manual with a torque angle meter. The crank balancer bolt is a good example.
[Modified by BHP, 10:18 PM 4/10/2004]
Old Apr 12, 2004 | 03:35 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: TORQUE TO YIELD-ft.lbs then degrees?? (BHP)
Or headbolts, or maincaps. It's a little bit of a PITA.
To TORQUE TO YIELD-ft.lbs then degrees??
