2005 Electric Steering?
Old Apr 14, 2004 | 10:59 AM
Suttleone's Avatar
Suttleone
Default 2005 Electric Steering?
I have been trying to sniff out un-announced changes due on the 2005 by studying the Cadillac SRX. It has rack and pinion electric assisted steering. Has anyone heard if this is going to be in the Corvette too? I've read that it is a great improvement over hydraulic assist on european cars. Its better on fuel consumption also. (I inadvertently posted this on the C5 Forum too. Sorry.)
Old Apr 14, 2004 | 10:35 PM
SWCDuke's Avatar
SWCDuke
Default Re: 2005 Electric Steering? (Suttleone)
I've seen no mention of anything "new" about the C6 steering, so I believe it's safe to assume that the C5 Magnasteer system has been carried over, probably with minor tuning changes.
The Z51 package includes a P/S cooler, which would probably not be necessary with an electrohydraulic system, since the electric motor only turns the pump fast enough to provide the necessary boost, or in the case of some systems, provide a direct electrically actuated torque assist to the steering column.
Duke
Old Apr 15, 2004 | 08:48 AM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: 2005 Electric Steering? (SWCDuke)
You are correct. GM even stated that the caster angle has been changed to help the C6 avoid following ruts in the road.
To 2005 Electric Steering?
