Octane requirements decrease with altitude. What's the elevation there? Ususally, they sell high enough octane for a given elevation to support any "stock" vehicle.
Except in kooky California, where 91 is all we have down to 282 feet below sea level (Death Valley).
Octane requirement for given engine is VERY loosely based on elevation. It is a function of cylinder pressure, affected by altitude, but it is also affected by chamber design, piston top design, compression ratio, and in general, cylinder pressure. Octane levels change little across the country due to supercharged and turbo vehicles maintaining cylinder pressures even at higher altitudes.
It will be very hard to make a statement about the LS2 and octane until after it is out and several people start testing it. The LS6 is sensitive to octane, though, and it would be a good prediction that the LS2 will maintain that sensitivity(chamber design appears to be LS6 at this time).
Most of the octane boosters claim to be cat safe, but most of them do not raise the octane rating of fuel more than 2 to 3 points. It may be just enough in some cases, but I don't think the cost over the long run justifies them.
Michael
Try Union 76. Some of them sell 104 unleaded racing fuel - about $5/gallon, but 1-2 gallons in a tank really woke my zr1 up. I don't buy the altitude thing - regular in SD is 85 octane, premium is 91 and the zr1 pinged like crazy on 91 here too.
Yeah, I have a feeling I'm going to be doing the multi-pump shuffle every other time I buy gas, but I would rather spend an additional $5 on fill-ups than hear a ping or risk damage.
Las Vegas not only has 91 octane premium, but we are in the high desert.
The reduced O2 content results in a slower burn, and less HP. That's the reason gas stations at higher elevations sell premium with a lower octane rating (91 vs 93) and 85 octane vs 87 regular. I didn't say I endorsed it. But I've spent enough time at higher elevations and lower elevations to see this trend. Some peoples cars ping on 94 octane. They have other issues (like reformulated blends that are required in the People Republic of Kalifornia).
