C6 Chassis Dyno Numbers Inside (Actual)>>>>
I agree that the engine is begging for a longer duration cam. After I drove the C6 for a day, I came to the conclusion that a cam change will take place as soon as I can get my car and camshaft in my hands.
The drivability due to the broad torque curve of the new C6 is actually better than it needs to be. That indicates to me that a slightly "bigger" cam will still provide very acceptable drivability while delivering more horsepower. GM always utilizes cams that are very conservative on valve lift for durability reasons on stock engines. Although they claim a higher lift cam in the new LS2, the better breathing on both intake and exhaust sides will benefit greatly by increasing the lift further.
Assuming 12% drivetrain loss, it should be around 352rwhp. Many feel the loss for the manual C5 was closer to 15%, which should put it around 340rwhp. Either way, these dyno results are very close to what GM is advertising. It can't see them underrating the C6 anyway, since hp #'s are so important in marketing for performance autos. The only reason they underrated the F-bodys was to protect the marketing image for the Vette. With the C6, there is no higher performance car in GMs lineup to protect.
I agree, if I was getting a C6, I'd be salivating at a cam swap.
It appears, as BluByU says, the cam is the 2001 Z06 cam, leaving another 10 or so HP on the table for next years upgrade.
The intake system will be pretty hard to beat on the dyno, with maybe 10 RWHP left over for the aftermarket.
I believe the C6 has gone back to the laminar screened MAF sensor used on the 2001 Z06 for better metering and less codes from turbulent airflow at low rpm. Good news for us.
Jim Hall
Jim Hall
My understanding is that the LS2 cam uses the '01 LS6 lobes and lobe phasing, but the part number is different due to some other features of the camshaft (not directly bearing on valve timing) that are different than the '01 LS6 camshaft. LS2 uses the same valve spring, but it has a new part number, and I believe the LS2 spring has become the service spring for '01 LS6.
The '01 LS6 lobes are as aggressive as possible using solid valves. The '02-'04 LS6 lobes have more aggressive acceleration profiles, but require the lighter, hollow valves.
Duke
