C6 Chassis Dyno Numbers Inside (Actual)>>>>
Old Aug 3, 2004 | 09:43 PM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
Default C6 Chassis Dyno Numbers Inside (Actual)>>>>
For those that are interested:
We had an opportunity to chassis dyno pull a stone stock C6 w/ an M6 today and we are pleased to see that it shouldn't be too difficult to produce some very good, clean power with this new platform.
- 347 RWHP/ 349 RWTQ
- Over 300 ft./lbs. RWTQ from 2616-5947 RPM
- RWTQ Peak: 4527 RPM
- RWHP Peak: 5944 RPM
Dyno cell conditions:
94* ambient
97% humidity
Road test highlights:
We also drove the car for quite a distance over different types of roads and found it to be a much more refined version of the C5. The magnetic suspension reacts to road irregularities with amazing speed~ in fact, un-detectable and the transmission shifter feels very positive. (a refined Hurst feel) The clutch is supposed to be stronger, but it feels very mushy due to even less pedal effort required to make it release. (it feels as if nothing is even there......odd indeed)
This particular model had the new Navigational System and it was interesting to watch yourself travel over the streets you are looking at right over your shoulder. The push button starter certainly is going to take some getting used to and the fact that the car doesn't have ANY door handles~ AT ALL, makes us somewhat nervous......
Anyway, to shorten this; from our standpoint, it appears as if the car is an overall improvement powertrain wise and it definately will give us tuners a much better platform to make upgrades in nearly every catagory of development. We're not too sure if we like the ergonomics or some of the body re-styling que's just yet, but maybe if we give it a bit of time, it may grow on us. The big butt of the C5 did.....
Best Regards,
DTE
Old Aug 3, 2004 | 10:02 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Great numbers.
For comparison, my 99 coupe #'s
312RWHP/324RWTQ
Only mod is Borla Stingers.
Old Aug 3, 2004 | 10:19 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Thanks for the info. I believe you hace "scooped" the rest. Were those corrected numbers? Your atmosheric conditions are definitely poor for performance. Can you post a graph?
Old Aug 3, 2004 | 10:21 PM
need-for-speed
CI 1-4-5-8-9-10 Vet
Thanks for the info. I believe you have "scooped" the rest. Were those corrected numbers? Your atmosheric conditions are definitely poor for performance. Can you post a graph?
Old Aug 3, 2004 | 10:25 PM
DTE Powertrain
Collections Hold
All of our publised power output numbers are corrected and we agreed not to post a graph until the car is released.
Best Regards,
DTE
Old Aug 3, 2004 | 10:47 PM
Wadoka's Avatar
Wadoka
Cruise-In 1-2-3-4-5 Veteran
And that's as she drives, with all of the accessories belted up and running, right? No rigging of numbers by taking the belt off, eh?
I can deal with that. My stock 99 made 311HP/317FT# on a fairly cool day.
Old Aug 3, 2004 | 10:55 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
What brand of dyno was used ?
Old Aug 3, 2004 | 11:00 PM
hngacurv's Avatar
hngacurv
Old Aug 3, 2004 | 11:31 PM
chadwick's Avatar
chadwick
Huh. That's only 17 more ft-lbs rear-wheel torque than my stock 2001 coupe.
HP increase is right where it should be, nice.
Old Aug 4, 2004 | 07:57 AM
scorp508's Avatar
scorp508
How many miles were on it? Was this a production model with the final tuning?
I love the torque over 300 ft/lb for sooo long.
Old Aug 4, 2004 | 08:43 AM
C5 CU's Avatar
C5 CU
dyno on bone-stock C5s with under 500 miles and then again after 1500-2000 miles showed approximately 5-8 rwhp gain after "break-in" milage...lots of Forum discussion about was this result of built-in programing from GM. But if from programing or from motor itself it was common to see...maybe the C6 347rwhp after a few hundred miles will also pick up a few hp and break 350rwhp...almost exactly the same as 02-04 ZO6.
Old Aug 4, 2004 | 09:50 AM
DTE Powertrain
Collections Hold
These power numbers are what they are......
Best Regards,
DTE
Old Aug 4, 2004 | 10:33 AM
c6gofst's Avatar
c6gofst
Best Regards,
DTE
Old Aug 4, 2004 | 11:15 AM
hippy's Avatar
hippy
Look at the temp and humidity too, not the most ideal conditions either.
Old Aug 4, 2004 | 12:11 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Makes me happy with my 352rwhp C5 (dynoed on a rainy day and I mean RAINING! ) also more reason to hold on till the C6Z06...I can't wait!
Old Aug 4, 2004 | 12:30 PM
wstory1's Avatar
wstory1
Old Aug 4, 2004 | 12:52 PM
LowFlight's Avatar
LowFlight
St. Jude Donor '03, '17
Senior Member
Cruise-In V Veteran
That is better than your typical C5 Dyno SAE vs RWHP, however, I was hoping for another 10-15 RWHP to build on to be really competitive in straight line performance.
To C6 Chassis Dyno Numbers Inside (Actual)>>>>
Old Aug 4, 2004 | 05:10 PM
The Example's Avatar
The Example
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Well the Horsepower numbers are right where GM claimed, so it looks like I was wrong by saying that it'd be underrated from the factory to placate the C5 owners...however perhaps there is a slight tweak that can/will be done in the next model year to bump it up a few horses? Plus this is the only one that has been independently dynoed that I know of.
I like the numbers either way, love the torque curve, and salivate at the possibilities of merely putting in a '02 Z06 cam.
Old Aug 4, 2004 | 05:45 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Not necessarily. We don't know if the motor is underrated or not since this was a dyno at the rear wheels. We don't know for sure how much the drive train is losing without taking the engine out and dynoing it directly.
Old Aug 4, 2004 | 05:52 PM
Lazerwolfe's Avatar
Lazerwolfe
From: I am Jack's out-dated Fight Club reference. MD
Seems like good numbers to me.
