breaking in period? limits?
Here is the original thread
http://forums.corvetteforum.com/show...light=break+in
This is shear torture. Must have been written by some sadistic engineer at GM!
Aaarrghhh!
Aaarrghhh!
They take 'em to red line on the factory dyno.... Every one of them, and at speeds considerably higher than 55.
Here is a link that seems to have helped many:
http://www.mototuneusa.com/break_in_secrets.htm
Now I have no idea who to believe. I figure I'm screwed no matter what I do to it.
I completely agree. When you think about it, once the oil pump builds up pressure there is NO metal-to-metal contact in the engine. There is truth in the portions of this thread dealing with thermal cycling of parts to give them a proper "tempering" with use. But as far as an arbitrary speed limit of 55 mph is concerned, that has GOT to be a lawyer talking. I haven't done the math, but I suspect the engine would only be turning over about 1400 rpm at 55 mph. You are in considerable danger of lugging the engine down to a low enough rpm that the oil pump may not be putting out sufficient pressure to prevent metal-to-metal contact between highly-loaded parts that should be separated by a thin oil film. The above assertion about taking the brand new engines to red line is quite likely true. They know that some owners are very likely to do exactly that and if yours was put together with some flaw that would not let it survive a blast to the red line, they want to know that before the car leaves the factory. There is one school of thought that the proper way to break-in any engine for maximum performance is to run it HARD right from the get-go. This has been shown (in at least some tests) to produce better overall ring sealing and ultimately the highest horsepower. Whether the rings will have the same potential life span with this hard break-in procedure is a bit less definite. For most of us, some compromise in the middle of the super-conservative factory recommendation and the "all red line all the time" methods would probably make the best sense in terms of the most performance for the longest time.
When I drive my C6 home from the factory, I'm going to concentrate on doing a fair number of accel/decel cycles under light loads with freqeunt varying of engine speeds. As for revs, I won't hesitate to take the engine up to 3000 to 4000 rpm during the first few miles. BUT the key to the revs I use will be that I will always keep the engine spinning freely -- i.e. never lug it down with high loads and low revs. By 500 miles or so, you should be ready to expand the rev limit a bit higher. Certainly, by 1000 miles, you ought to be able to take it right to the red line as often as you feel so moved. The parts are going to be thermally conditioned by then and the aforementioned film of oil insures that there will be essentially no wear on the engine once the crank turns a few times and the oil pump builds up pressure on every start-up.
If we are honest with ourselves, we will admit that Vettes are fast enough that you will rarely NEED to exceed 3000 rpm in normal driving to sprint 'way ahead of most other traffic. Those runs up to red line are us acting out our boyhood fantasies of what driving a race car would be like. Not necessary, but a lot of fun. Just like the kid dreaming in the commercial that they pulled. We all had fantasies like that and a Vette is the car to make those fantasies real.
The main thing is to get in them and drive them properly and skillfully. Don't let them sit in the garage and gather dust. Vettes are for driving!
The rear end gears defiantly need at least 2 heat cycles. The gears mesh tighter when they are new and will run hotter. The gears should be run between 45 and 65 MPH for an hour to hour and a half. Then the gears need a good six to eight hour cool down.
There is also a period of computer learning to also take into consideration.
These are my opinions, that does not mean others are wrong, but it is what I recommend.
Aaarrghhh!
Where did that come from???????
During the C5 develoment and track testing, the TEST cars were run at full throttle for one tank of fuel, this just happened to take approx. 30 minutes at the rate of fuel consumption at full throttle.
Chevy doesn't have the time to run each car for 30 minutes, it's a quick dyno scan, then out the door to the lot, and on the trucks as quickly as possible.
zo6vettepilot
