26HP from Headers
Old Sep 29, 2004 | 01:55 PM
Blocktrdr's Avatar
Blocktrdr
Ernie uses a Mustang Dyno. It is probably a good part of the reason his numbers are a little lower. Also, something that always seems to get overlooked. Cars make less power here than in the most of the country. It is over 90 degrees right now and the humidity could be cut with a knife. 320 RWHP here, right now, is probably 340 RWHP up north.
Old Sep 29, 2004 | 02:23 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Originally Posted by bpproducts
Adam like you said the autos always read less. It seams that everyone thinks the sticks dyno the same as the autos. Most of the C6s that you see out there that have been dynoed have been the sticks so when an auto comes up they think the numbers are way off. Lets put it this way if the autos had the same RWHP they would be quicker then the sticks down the 1/4 mile.
Ernie
www.BreathlessPerformance.com
For christ's sake .....I KNOW they dyno lower. Reading is fundamental people. I have owned BOTH a A4 and M6. I think people are reading too fast.....my poist says "stock" not "stick"..............
In any event.....it is still a low dyno.
Old Sep 29, 2004 | 02:39 PM
Adam Bruce's Avatar
Adam Bruce
Originally Posted by -Blue Vette-
A stock C6 A4 should dyno around 350 @ the wheels.
No, if the A4 made 350 at the wheels stock then it would be making 437 crank hp.
400hp - 20% loss = 320 RWHP
Old Sep 29, 2004 | 02:47 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Except that the A4 doesn't have 20% loss.
17% for the 3.15 and 14.5% for the 2.73 Automatics.
Old Sep 29, 2004 | 03:15 PM
bpproducts's Avatar
bpproducts
At 17% 350RWHP would be about 421 Flywheel which is not what the C6 comes with.
330RWHP would be about 400 Flywheel at 17%
325RWHP would be about 400 Flywheel at 18%
Ernie
Old Sep 29, 2004 | 03:16 PM
bpproducts's Avatar
bpproducts
By the way we do use SAE correction factors.
Ernie
Old Sep 29, 2004 | 04:43 PM
Adam Bruce's Avatar
Adam Bruce
14.5%? Wow that's an efficient Automatic. GTO's get 15% loss on their 6-speed Manuals!
Old Sep 29, 2004 | 04:56 PM
jimman's Avatar
jimman
Has anyone ever seen the dyno charts of the raw engine?
Old Sep 30, 2004 | 01:20 PM
427Z0SX's Avatar
427Z0SX
Promising results, but it's only 1 car. Statistically insignificant. Hard to say either way, let's wait until some more people get their cars modded.
Old Sep 30, 2004 | 01:37 PM
WhiteDiamond's Avatar
WhiteDiamond
St. Jude Donor '15
The dyno reading higher or lower has NO effect on this discussion, as long as the before and after dyno's where done on the same dyno. If so, the air intake gains are a complete lie and it is very disappointing to see on the forum. I highly doubt this dyno is significantly low, as the after numbers for both the intake and exhaust combined are in line with what respectable dyno graphs are getting with just headers.
Todd
Old Sep 30, 2004 | 03:41 PM
Scissors's Avatar
Scissors
Ernie
The C6es with automatics and 3.15 gears have been averaging out to 330-335 RWHP.
Most of the dynos I've seen have been of manuals and they've been cranking out high 340s to low 350s. Which would be about 402 crank HP.
Old Sep 30, 2004 | 03:45 PM
Scissors's Avatar
Scissors
Well obviously. That's what happens when you compare a car with 2.73:1 rear gears to one with a 3.46:1 ratio.
The drivetrain consists of a transmission and a differential, and both have an affect on the drivetrain loss. That's why the dyno is performed in 4th gear (3rd for the A4): because a 1:1 ratio is the most efficient.
Those numbers are also based on many, many dynos by C5 owners. Since the differentials are the same and the transmission is almost the same, the results should be the same as well. Or at least very, very close.
Old Oct 2, 2004 | 03:33 AM
  #33
Michael A's Avatar
Michael A
Well the numbers are in.
With the Vortex ram induction 349 to 353 RWHP
Ernie
Ernie,
When you put this Vortex ram induction on, did you change anything in the engine's calibration?
Did you put the stock air cleaner back on to see if you could repeat the baseline horsepower?
Michael
Old Oct 4, 2004 | 10:49 AM
  #34
bpproducts's Avatar
bpproducts
Nothing was changed in the computer and yes we did change it back 3 times to verify the results.
Ernie
Old Oct 4, 2004 | 11:50 AM
  #35
Iboomalot's Avatar
Iboomalot
some motors are not always that great on a dyno.
my car stock only did 283 - 293 on a dynojet
but my car is a M6 1999 rated at like 350hp so maybe they got
one that just dynos bad.
either way thanks for the info
Old Oct 4, 2004 | 08:42 PM
  #36
jschindler's Avatar
jschindler
Actually, using the 18% loss for A4's (that was considered normal for C5's), would put it at 328. So the 320 seems a little low, but not too far off.
But the horsepower gain adding the Vortex does seem awfully optimistic. I hope it is true, but will l be surprised if it is. And please understand I have no bone to pick with the Vortex - I have had one on both of my C5's.
Old Oct 4, 2004 | 09:32 PM
  #37
jimman's Avatar
jimman
thought everyone used 22% for auto and 15% for manual. Has anyone seen an actural engine dyno graph. Sure would like to put this percentage thing to bed.
To 26HP from Headers
Old Oct 5, 2004 | 05:58 PM
  #38
Scissors's Avatar
Scissors
The forum's very own performance registry can help.
pewtery2k's 2000 A4 Coupe with 3.15:1 rear gears resulted in a dyno of 294.4 RWHP. This is the lowest score in the performance registry for cars with stock intake and exhaust. This is a 14.7% loss--even better than the average of 17% that I've seen for such cars.
But also provided is the temperature (63.7 degrees) and the barometer (29.71 inches) at the time of the dyno.
Using an SAE correction calculator, this results in anywhere from 1% to 3.5% more HP (depending on a high or low relative humidity respectively.)
1% means that the SAE corrected number would be 291.456 and 3.5% would be 284.096 RWHP. Or, in other words, an SAE corrected drivetrain loss of anywhere from 17.65% (0% humidity) through 15.52% (100% humidity.)
Summary: This particular stock 2000 A4 Coupe w/ 3.15 had a 14.7% loss if the dyno was already SAE corrected, and anywhere from a 15.52% through a 17.65% loss if the dyno was not already SAE corrected (depending on relative humidity.)
Old Oct 5, 2004 | 07:21 PM
  #39
jschindler's Avatar
jschindler
All it takes to make a chart is numbers! We must remember that not all dynos are created equal.
Old Oct 5, 2004 | 07:43 PM
  #40
jimman's Avatar
jimman
You've defended your percentage numbers for the Automatic, how about the manual tansmission, what do you get with that.
