Jacking Pucks
Old Oct 1, 2004 | 01:59 PM
SEA6's Avatar
SEA6
Default Jacking Pucks
Does anyone know if the C6 uses the same slots in the frame as the C5 does and will the C5 Jacking Pucks work in the C6
Old Oct 1, 2004 | 04:57 PM
LS WON's Avatar
LS WON
Is it necessary to use the pucks on the C-6?
Old Oct 1, 2004 | 05:40 PM
SEA6's Avatar
SEA6
Old Oct 2, 2004 | 06:33 AM
C8-Vette's Avatar
C8-Vette
When my C6 was delivered on Wed. it was put on the dealers lift. The mechanic showed me the 4 holes /lift points. He said they were the same size as the C5-so I guess the answer would be yes. Puck will fit!
Old Oct 2, 2004 | 08:36 AM
SEA6's Avatar
SEA6
Thanks C6Vette
That is what I was hoping.. Good luck and many happy miles
Old Oct 3, 2004 | 06:03 AM
LS WON's Avatar
LS WON
So what happens if you don't use those pucks before putting the Corvette up on the rack?
Old Oct 3, 2004 | 08:44 AM
SEA6's Avatar
SEA6
Without the pucks or some other spacer the glass body panel can be damaged were it covers the frame when lifted.
Have a look at the links below
http://www.madvet.com/shop?frame=1.174
http://www.idavette.net/hib/C5diy/c5diy1.htm
Old Oct 4, 2004 | 02:05 AM
LS WON's Avatar
LS WON
Where can I purchase these pucks?
Old Oct 4, 2004 | 08:35 AM
SEA6's Avatar
SEA6
Assuming that c6vette is correct that they will fit, there are several
places you can purchase the pucks. I purchased mine for the C5 at
Forum vendor LAPD. Give them a call, I am sure they will confirm
weather or not they will work. Let us know what you learn ...
http://www.thelapd.com/Merchant2/mer...e_Code=thelapd
http://www.thelapd.com/Merchant2/mer...egory_Code=ptc
Old Oct 4, 2004 | 04:12 PM
LS WON's Avatar
LS WON
or you can make your own...Thanks
Old Oct 4, 2004 | 05:11 PM
Rob 2K1's Avatar
Rob 2K1
Just use hockey pucks. They work great and cost a lot less than the fancy lifting pucks.
-Rob
Old Oct 5, 2004 | 09:44 AM
Mark S.'s Avatar
Mark S.
There is another option...pick up lifting pads/pucks from your local BMW dealer (for the 3 series)...they cost about $35 for four of them and you can permanently mount them (they snap right in) and they have lower profile so that you have to get on the ground to actually see them. This way you don't have to worry about taking your vehicle in and ensuring that the tech uses the proper pads or that he put in the ones you've asked him to use...these will save you a lot of headaches.
Old Oct 5, 2004 | 07:04 PM
LS WON's Avatar
LS WON
So go down to the BMW dealer and ask them for?? what do they refer to them as pucks also? In stock? or special order?
To Jacking Pucks
