Will the C6 clutch be the same units that fit the C5? The Transmission is the m12 and the block is similar so I was hoping the available C5 clutches and aluminum flywheels will fit.
At the Corvette Funfest at Effingham IL last month Fidanza had a display and rep present. They already had a new C6 aluminum flywheel developed. Around $469 if my memeory is correct.
