I just bought the resister from Radio Shack (5 for $1.29 or something), and with some instructions from the Forum, I had the mechanic put it in when doing my first oil change...took maybe five minutes. Unfortunately, I don't remember which resistor to get, but if you look it up in a search in the C5 section it will tell you.
Resistor 2200 Ohm-1/2 Watt Radio Shack p/n 271-1121 --5 ea. for $1.00 Takes minutes to install. Save 20 bucks! (only need 1 resistor)
What are you Radio Shack guys doing to weatherproof the connectors on both the PCM and tranny sides? Seems like $20 isn't much to pay to make sure the connections are weatherproof.
