Lift Points for C6
Old Nov 27, 2004 | 10:52 PM
Buster1's Avatar
Buster1
Default Lift Points for C6
Okay, the pics in the manual for where to lift the C6 are pretty bad. (IMO). I just want to be sure before I do anything rash.
If I'm using a 4-arm type lift (not a jack), do I put the jacking pucks in the little slots directly behind the front wheels, and right in-front of the rear wheels? The slots look about right but not sure if they are in the frame or body. They're pretty close to the edge of the car.
Any experience would help.
Old Nov 28, 2004 | 12:15 PM
SA734's Avatar
SA734
You are right on.
Old Nov 29, 2004 | 04:19 AM
LS WON's Avatar
LS WON
Default Did you get the jacking pucks at BMW?
fyi: There are two types of jacking pucks for the Corvette but these you can leave on the car all the time it just screws in and it rectangle shape I believe. It is definitely not the round pucks that stay in but the others if you happen to go down to BMW.
Also have you tried Rhino Ramps?
To Lift Points for C6
